Never really lowered suspensions.. what do I need how do I do it? Or should I take to a shop
buy my coilover parts i have for sale on here, build a set of coils for the front, and drop it, hell, you could even give it some rake stance, not that you should considering its fwd...
read my above post....
I have parts for sale (you'll need a couple other pieces) and you could DIY a set of FRONT coilovers.... If you know what coilovers are, you know that you can choose the height they sit at...
well you'd have to finish building the coils, and just take the stock stuff out, put the coils in
lowering springs involve having to take your stock stuff out, apart, back together and back in the car.
Same as what? Stock or sagged? Both are not usually true.
I think they are pretty close to stock usually, maybe a half inch higher. Much tougher than stock though. I have kyb quick struts all around and the front is definitely a bit higher than the rear if you really compare.
That's what needs to be done. If the front hasn't sagged much it shouldn't look too bad. And also I have almost nothing in my trunk, so if you had a few things like a sub it would probably be right at stock height.
