Thread: something is loose
Results 1 to 20 of 26
  1. #1 something is loose
    Oct 2014
    United States
    Well i just bought a new to me GTP (RED 4dr) on monday for $1300 and 163k miles, with a couple leaks and no SC belt :/. I cleaned the engine off and noticed that an oil drip i saw on the ground was coming from my rear valve cover. Too easy, will change that gasket along with the LIM gasket. Guy who sold it to me also said it goes through power steering fluid so i need to hunt that down. But one thing i don't know is that when the car is going 20-40 mph and steering is in nuetral position there is a rattling/clunking around that goes away as soon as i start steering left or right. Seems like something is loose down there and is tightened up when the rods pull it left or right.
    Any idea where I should start looking? I initially thought it was the CV axle but that would be more prominent with turning i would imagine, not just when going in a straight line. Its no better or worse when speeding up or slowing down.
  2. #2 Re: something is loose
    could be the sway bar ends are busted off or 1/2 broken off. they are hollow and rust and break.
  3. #3 Re: something is loose
    St. Louis
    Tie rods, rack, swaybar (as mentioned), lower control arms could all be suspect. Time to jack the front end up and push/pull and visually inspect it all. The loss of PS fluid could be the rack itself leaking.
  4. #4 Re: something is loose
    Oct 2014
    United States
    Yeah I was thinking the rack and praying it isn't it
  5. #5 Re: something is loose
    Racks an easy swap
  6. #6 Re: something is loose
    Come change mine for me smutty.
    Sent from A Galaxy Far Far Away........
  7. #7 Re: something is loose
    Oct 2014
    United States
    Think my biggest hurdle is the complete lack of a flat surface to park on and the 45 minutes of daylight after fighting Atlanta traffic after work.
    Currently at my brother's house until I get an apartment and my family moved from Augusta to Atlanta.
    So I go home every weekend and still need to register and insure the car. So no driving it home on the weekend yet to work on it.
    What I wouldn't give for a lift to put big red on
  8. #8 Re: something is loose
    Quote Originally Posted by Slick2500 View Post
    Drive over here
  9. #9 Re: something is loose
    Drive over here
    F that noise, it's like 1600 miles to Ohio.
  10. #10 Re: something is loose
    Oct 2014
    United States
    Ok rotated tires and have everything a really good tug while the wheels were off... Nothing lose. Tire wasn't the problem noise is still there all connections are tight, no dry rot on any boots and bushings look good. Where the hell could this be coming from? Def need new rotors tho, mine are grooved pretty bad. Can CV axle be hosed and all boots be perfect?
  11. #11 Re: something is loose
    St. Louis
    Yep, sure can. I snapped my pass. side axle earlier this year and it didn't have a torn boot before it broke. Replace both rotors and see what you get.
  12. #12 Re: something is loose
    Oct 2014
    United States
    Yeah it's just weird that the knock knock knock is only when going straight from 20-40 mph. Like something is banging back and forth
  13. #13 Re: something is loose
    I shake the down front ends with the tires still on. Only way to see if tie rods or beraings are loose. Unless it's about to fall out bad.
    Without the car at my finger tips I can't really say what it going on.
  14. #14 Re: something is loose
    Oct 2014
    United States
    Yeah I hate it, but plus side... Everything I replace will be better than stock. So if I can't find it, it will only handle better and better lol
  15. #15 Re: something is loose
    Oct 2014
    United States
    Well I think I found the problem.
    Could shake the wheel back and forth with about an inch of play and loud clunking
  16. #16 Re: something is loose
    time for outer tie rods.
    crack the lock nut free on the rod, then take the castle nut off and cotter pin, then with a hammer hit the flat part at the end of the knuckle, the joint will pop free with a few good hits.
    leave the lock nut in place, remove the old ends, turn the new ends back on the rod tot he old lock nut, snug it up.
    you'll need an alignment but it will be close if you dont move the lock nut.
  17. #17 Re: something is loose
    Oct 2014
    United States
    How much better are the Moog vs any other cheaper $25 tie rod end?
  18. #18 Re: something is loose
    id get the better moogs. or a name brand before them real cheap o's. you want them to last. make sure the new ones have a grease fitting, and you grease them when installed.
  19. #19 Re: something is loose
    Not much better.
    Get one with a grease zerk is my own request.
    And that looks like a factory tie rod end, so there won't be an cotter pin as it's a nylon locking nut.
  20. #20 Re: something is loose
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    Your always welcome to come over to the garage :roll eyes: I'm a mile from 6Flags off I-20 West in Mableton, about 5 miles from I-285. Have lift and all the tools to work on W-bodys or 3800's. Call me 770-630-1609
    John K
  1. Loose Wires
    By Skoll in forum Brakes/Suspension/Chassis
    Last Post: 07-02-2012, 07:57 PM
  2. Loose Connector
    By ShadowSwept in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-20-2012, 01:23 PM
  3. 04+ Loose fog light??
    By gpse2000 in forum General Grand Prix Discussion
    Last Post: 03-26-2012, 08:46 PM
  4. HELP ! can not get my bolt loose HELP !
    By pughman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2011, 08:11 PM
  5. something seems loose
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 03-08-2008, 01:55 PM
