Thread: Which way to turn bolts on caliper
Results 1 to 20 of 35
  1. #1 Which way to turn bolts on caliper
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    Doing brake pads and rotors which way should i turn the bolts for the 15mm. They are on there really snug and cant seem to get to go either way and dont wanna tighten it more. Lefty loosey righty tighty?
  2. #2 Re: Which way to turn bolts on caliper
    C'mon man, of course its left to loosen. Get a better wrench or a cheater bar.
  3. #3 Re: Which way to turn bolts on caliper
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    iirc they all loosen to the left like normal. I had to use a small pipe on the end of the ratchet to be able to get enough torque to break them loose.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  4. #4 Re: Which way to turn bolts on caliper
    just set the ratchet to loosen then put it on the bolt. leverage is your friend.
    i always spin the ratchet in my fingers before it goes on a bolt. righty tighty, left loosy
  5. #5 Re: Which way to turn bolts on caliper
    Aug 2012
    Brainerd, MN
    I figured, the brake rotors look like they havnt been changed in years ended up ordering some of them. I was planning on only doing the pads and getting it ready and putting front end on blocks. Got it sittting in garage right now, waiting on the pads hoping they come on saturday.
    Ganna prob set the tie rods while im down there the steering wheel sits at 2 o clock see if i can figure that project out. ganna be sittting on blocks for a week i would say, ordered the rotors tuesday at 3pm, and still not shipped.
  6. #6 Re: Which way to turn bolts on caliper
    Let a shop set the alignment, doing it yourself just screws it up.
  7. #7 Re: Which way to turn bolts on caliper
    take it to a shop its 75 bucks for a real alignment.
    those rotors look like they've seen better days.
  8. #8 Re: Which way to turn bolts on caliper
    Aug 2012
    Brainerd, MN
    It would high pitch squeak when going like 35 mph, then hitting brakes pretty hard to go down to 20 would make it stop, not sure if its the rotors, pads or whats going on with that but the brakes are pretty weak when i drove it so im doing the pads, and now the rotors after i took the wheel off.
    80$ for alignment at dealership i went to. they also said it was leaking oil from oil pan and rear main seal, which hasnt leaked a drop or moved on the diptick. I could see oil on the control arm i think it is, not exactly sure i would bet that the oil pan is leaking, or seaping, but it doesnt look bad when its not dropping any on the floor.
  9. #9 Re: Which way to turn bolts on caliper
    dead pads, aka no meat left, on the squealers.
  10. #10 Re: Which way to turn bolts on caliper
    Aug 2012
    Brainerd, MN
    I figured it was the pads doing the sound, and when i seen the rotors i was like i dont these will work
    What do you think caused the rust in between the lugnuts on the rotors? The rotors look really bad, but thats what got me is the rust in between the lugnut bolts. Was told car sat for about 18 months before i bought it, but i dont know if its true. has 165K miles 2004 gt.
  11. #11 Re: Which way to turn bolts on caliper
    to bad you ordered parts already, this is the perfect time to up grade the brakes to F bodys. those stop real good.
  12. #12 Re: Which way to turn bolts on caliper
    Aug 2012
    Brainerd, MN
    Plan on driving it this winter, then selling, got it for 2300. I just dont wanna drive my 01 gt with 56K miles in winter time in MN. rather crash the 04 than the 01
  13. #13 Re: Which way to turn bolts on caliper
    Moisture, water, snow, salt all touch the rotors where you live, thats why there is surface rust there.
    Completely normal. Look at the backside of the rims, the same spots on there will have corrosions from the aluminum touching the steel. It's just what happens where you live.
    On these new rotors, clean them with parts cleaner and what not and then paint them black to protect the surface if you want. It will slow down the surface rust.
  14. #14 Re: Which way to turn bolts on caliper
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    If you haven't pulled the bolts off yet, might want to give it a shot of PB blaster every day until your new parts show up.
    Rust could be the issue, also could be some redneck not torquing the bolts properly and/or using red loctite on the threads.
    If they used loctite, a torch on the bracket around the bolt would probably be the best bet for getting off.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  15. #15 Re: Which way to turn bolts on caliper
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    I love PB blaster. Fixes everything
    04 GTP -HAI, 1.9 rockers.
  16. #16 Re: Which way to turn bolts on caliper
    Enfield, CT
    ^^^^^THIS^^^^^
    BTW, get a real jack too
  17. #17 Re: Which way to turn bolts on caliper
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Quote Originally Posted by HighOctaneRacing View Post
    ^^^^^THIS^^^^^
    Jesus christ i just noticed that. Spend the 100 bucks on a jack and stands. Makes life so much easier and safe.
    Sent from BFE
    2012 F150 STX
    - Gonna be a race truck
  18. #18 Re: Which way to turn bolts on caliper
    stock jack and 4x4s are ok in my book. its called working with what ya got.....carry on, i got yer back on this one lol
  19. #19 Re: Which way to turn bolts on caliper
    Apr 2012
    Dayton, OH
    I can't really talk tho. I used the stock jack with no wood before i knew better.
    Sent from BFE
    2012 F150 STX
  20. #20 Re: Which way to turn bolts on caliper
    Enfield, CT
    Sent from BFE
    Knew better?
    you still don't know any better lol Jk
  1. Looking for 2 front caliper bracket bolts
    By raverockstar in forum Wanted To Buy - Parts
    Last Post: 04-09-2014, 03:10 AM
  2. Caliper Bolts wont budge
    By h0wl0ngcanitbe in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2012, 11:59 PM
  3. Please help Caliper mounting bolts
    By Cody Coy Ote Wesley in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2012, 03:48 PM
  4. caliper silde bolts drying out
    By asite57 in forum General Tech Discussion
    Last Post: 02-09-2012, 08:42 PM
  5. Stuck Caliper bolts
    By tjwenger in forum Brakes/Suspension/Chassis
    Last Post: 08-17-2010, 08:24 PM
