Thread: Which way to turn bolts on caliper
Results 1 to 20 of 35
  1. #1 Re: Which way to turn bolts on caliper
    dead pads, aka no meat left, on the squealers.
  2. #2 Re: Which way to turn bolts on caliper
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    I figured it was the pads doing the sound, and when i seen the rotors i was like i dont these will work
    What do you think caused the rust in between the lugnuts on the rotors? The rotors look really bad, but thats what got me is the rust in between the lugnut bolts. Was told car sat for about 18 months before i bought it, but i dont know if its true. has 165K miles 2004 gt.
  3. #3 Re: Which way to turn bolts on caliper
    Dec 2012
    Where 4T65E's were born
    Quote Originally Posted by Mirraco View Post
    Before you put the new rotors on, clean the hub surface of any rust, and apply a thin layer of antiseize. That's standard procedure at work. When I did mine I just cleaned them, and put the rotor on. Man was the rust thick 7 months later when I took them off again.. And I brushed some motor oil on thinking that would prevent rust, nope.
    Also clean the part of the rim that contacts the rotor of corrosion/rust from the previous rotors and use anti seize on that too. All of that will prevent rust/corrosion buildup and problems getting it all apart again next time. It will also prevent vibrations from rust causing an imbalance if its thick enough.
    Sold.
  1. Looking for 2 front caliper bracket bolts
    By raverockstar in forum Wanted To Buy - Parts
    Last Post: 04-09-2014, 03:10 AM
  2. Caliper Bolts wont budge
    By h0wl0ngcanitbe in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2012, 11:59 PM
  3. Please help Caliper mounting bolts
    By Cody Coy Ote Wesley in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2012, 03:48 PM
  4. caliper silde bolts drying out
    By asite57 in forum General Tech Discussion
    Last Post: 02-09-2012, 08:42 PM
  5. Stuck Caliper bolts
    By tjwenger in forum Brakes/Suspension/Chassis
    Last Post: 08-17-2010, 08:24 PM
