Originally Posted by iefalcon Assuming everything is tight right, what will happen if BCM unplugged. Not sure what you mean. Are you suggesting a loose connection? If so, where would I check for the bcm connector not having come loose? Thanks for all the suggestions so far.
Originally Posted by stargazer Not sure what you mean. Are you suggesting a loose connection? If so, where would I check for the bcm connector not having come loose? Thanks for all the suggestions so far. A bad BCM can lead to nonstarting and cutting power to some, especially the BCM work directly with the security system.
Forum Rules
