Thread: Check Engine code P0499 and P0455 P0455p
Results 1 to 5 of 5
  1. #1 Check Engine code P0499 and P0455 P0455p
    Mar 2014
    danville IL
    My 07 GT is throwing out three codes P0499 p0455 and p0455p its not the gas cap. please help.
  2. #2 Re: Check Engine code P0499 and P0455 P0455p
    could be the canister in the quarter panel under the gas door. or its solenoid on top of it. or the purge solenoid on the engine.
  3. #3 Re: Check Engine code P0499 and P0455 P0455p
    Would you please list the descriptions for the codes.
  4. #4 Re: Check Engine code P0499 and P0455 P0455p
    Mar 2014
    danville IL
    P0499 Evaporative Emission System Vent Valve Control Circuit High
    p0455 This indicates a fuel vapor leak or lack of purge flow in the EVAP control system. It means a large leak has been detected.
  5. #5 Re: Check Engine code P0499 and P0455 P0455p
    I'd check the wiring at the vent valve (which Scott is kinda mentioning) and if that's sticking open causing a high, then there's both issues.
  1. Trouble code P0455
    By powerranger262 in forum General Tech Discussion
    Last Post: 09-23-2014, 03:09 PM
  2. Check Engine Code: P0420 -- HELP!
    By JakeH0605 in forum General Grand Prix Discussion
    Last Post: 12-30-2011, 11:48 PM
  3. Check engine light/code
    By biggt in forum General Tech Discussion
    Last Post: 07-12-2011, 12:09 AM
  4. Check Engine Code Help Please!!
    By TGXP05 in forum 5.3L V8 (LS4)
    Last Post: 10-29-2009, 09:23 AM
  5. Check engine code P0440
    By c002529 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2009, 11:19 AM
