Thread: Check Engine Code: P0420 -- HELP!
Results 1 to 5 of 5
Threaded View
  1. #1 Check Engine Code: P0420 -- HELP!
    Dec 2011
    Anoka, Minnesota, United States
    Recently purchased my '05 Grand Prix Base the other day. At the dealership I was told the problem with the check engine light was a loose gas cap and it was fixed. Once I filled my gas tank the light returned. Using a home ODB-II scanner I found Check Engine Code: P0420 to be the problem. Everything seems to run fine and it has 128,000 miles on the engine. I am told it most likely an O2 censor, but I am worried it might be more. What should I do and do I need to worry, or this is a small matter to be solved when I can afford it...sooner rather than later of course.
    Thanks in advance!
    ...also, does anyone have a repair estimate for this? I am broke after totally my previous car and trying to budget.
  1. Check engine light/code
    By biggt in forum General Tech Discussion
    Last Post: 07-12-2011, 12:09 AM
  2. Check engine code: P0300?
    By CSteen85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-02-2010, 11:45 AM
  3. Check Engine Code Help Please!!
    By TGXP05 in forum 5.3L V8 (LS4)
    Last Post: 10-29-2009, 09:23 AM
  4. Check engine light on. Code: P0481
    By glomgold in forum General Tech Discussion
    Last Post: 03-22-2009, 04:10 PM
  5. Check engine code P0440
    By c002529 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2009, 11:19 AM
