Thread: RPM fluctuation due to subs?
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: RPM fluctuation due to subs?
    GT Level Member Trett93's Avatar
    Jun 2014
    Ontario Canada
    just cause youre running more doesnt mean youre using more than him, he could be on 400 watts making more power than your 900, all depends how its wired, either way youll never see full power out of an amp.
    3800 series 2 SC swap, 180 tstat, 5 speed swap, stage 3 clutch, machined camaro flywheel,
    s1x cam, rollmaster double roller, crow cams 105# springs, TR6's, overkill tune, ssbc big brake kit..more soon.
  2. #22 Re: RPM fluctuation due to subs?
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    Your subs are wired wrong, I had that problem for like 2 years, I just thought it was a weak battery or alt. pop your speakers out and make sure there wired for the correct ome (I don't think that's spelled correct), it was also causing my amp to over heat when I would crank it up.
    2004 Grand Prix GTP 150,000 " The New Edition "
  3. #23 Re: RPM fluctuation due to subs?
    Jun 2014
    Ontario Canada
    it doesnt mean its wired wrong, its either wired too low for the amp or youre trying to use too much power without feeding it enough power, i sold my buddy my first amps, 250rms ea, they ran fine in my car, but over heated and popped fuses alot till he added a capacitor, as for yours, you could have done the same, most amps are 1 ohm stable, or 2 ohms stable, anything less and they work harder and overheat causing major damage, now competition amps, such as sundown, dc, fi , hifonics, american bass ect, says theyre 1 ohm stable but some can take as low as .25 ohms, my hifonics was only 1 ohm stable but played at .5 aslong you have good electrical
  4. #24 Re: RPM fluctuation due to subs?
    I like the part of the thread where the OP says his ground is probably not as good as it should be.
  5. #25 Re: RPM fluctuation due to subs?
    Yoga city
    im laughing hard currently. only way my rpm; bounce is on a low note due to vibration. 3k in my daily no issues except maybe a loosing a volt on long notes. but like bill said big 3 is a must and checking power and ground connections will help. Clean the off, sand to bare metal. every little bit helps.
  6. #26 Re: RPM fluctuation due to subs?
    Jun 2014
    Ontario Canada
    he didnt say his rpm bounced, he said it drops due to lack of power/bad grounds, my spedometer bounced on high notes, my rpm dipped from the alternator making a huge electrical field, hence, slowing down the motor 200rpm, but i was in a 4 cyl car, not a 6.
  7. #27 Re: RPM fluctuation due to subs?
    Yoga city
    im in a V8 car, no issue there. Biggest issue I have is the compass getting out of wack. But then again there are 2 15's facing it.
  1. Subs... keep 'em still!
    By crysalis in forum Audio, Security & Visual Electronics
    Last Post: 07-27-2012, 05:33 PM
  2. Engine Temp Fluctuation
    By clintbaum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-10-2011, 08:04 PM
  3. RPM/ Power Fluctuation under load
    By HDDaveK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-06-2010, 10:59 PM
  4. Oil Pressure Fluctuation
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2009, 03:06 PM
  5. Temp fluctuation
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 10-11-2008, 08:28 PM
