Thread: OBD2 error on 08 grand Prix
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: OBD2 error on 08 grand Prix
    Not necessarily Scotty. The solenoid is merely an actuator that opens and closes. It may not be closing. The computer would still see it there...but it can't tell the position of the internal pintle.
    i hear ya jay but he needs to look for a busted line before buying parts. it lease i would.
  2. #22 Re: OBD2 error on 08 grand Prix
    Mar 2012
    NC
    I say get it smoke tested...that'll find the leak so you don't spend money unnecessarily.
  3. #23 Re: OBD2 error on 08 grand Prix
    if you dont find anything thats clearly broken, yeah thats the next step for sure.
  4. #24 Re: OBD2 error on 08 grand Prix
    Mar 2013
    Canada
    I went to buy the part from the dealership, actually it was cheaper then what I was quoted at another part place. He said I can return the item if I don't installed it, I also went to my local garage to see if they can do a smoke test and he said the the most common issue is the value, so when we do the smoke test we replaced the value. He said if you dont see anything that came apart then its the value same-thing what you guys mentioned. Im going to take a good look at it on Sunday and if I dont see anything loose then I will change the valve and go from there.
  5. #25 Re: OBD2 error on 08 grand Prix
    Mar 2013
    Canada
    Well I took a good look at the hose and seems fine to me, I ended up replacing the vent value on Saturday and the engine light has not came back since. Will keep on eye on it and see if it does but thanks for helping out
  6. #26 Re: OBD2 error on 08 grand Prix
    Mar 2014
    danville IL
    I also have the P0455 check gas cap code. tried a couple different gas caps and none seem to fit tight? not sure if it doesnt seal right or its for every grand prix.
  7. #27 Re: OBD2 error on 08 grand Prix
    Mar 2013
    Canada
    Well it's been over a week and no engine light so pretty sure my problem is fixed. Itzharrison my mechanic said it's a very common issue the P0455 error and 95% of the time it's the vent value. If you but the part from the dealer you will need a harness for the new adapter, not sure why they change the adapter on the newer parts
  1. Which OBD2 Reader???
    By 02GPinNY in forum General Tech Discussion
    Last Post: 10-07-2012, 07:10 PM
  2. OBD2
    By str3etgl0w in forum General Tech Discussion
    Last Post: 07-19-2011, 02:08 PM
  3. '00 Grand Prix - ABS/TCS light always on and Speedometer Error while in Neutral
    By ddsohn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 04:24 PM
  4. 1997 Grand prix odb2 communication error
    By kairo77 in forum General Tech Discussion
    Last Post: 12-26-2010, 10:00 PM
  5. OBD2 codes
    By sra_chipmunk in forum Forum Bugs/Suggestions
    Last Post: 01-14-2008, 12:56 AM
