Thread: Leaking heater core or much worse?
Results 1 to 12 of 12
  1. #1 Leaking heater core or much worse?
    Oct 2011
    Toledo, OH
    So my car has been sitting since July 3rd, today I finally got to drive it around the block, and upon getting home there is smoke pouring out the dash vents. I quickly rip apart the radio trim thinking its an electrical short only to realize it is definitely water vapor, and then notice the floor is completely soaked which I didn't notice this morning, checked and the radiator is dry.
    Since I've been under the car a lot the past few weeks, I know that there is no external leaks.
    So is a "just" leaking heater core capable of blowing water through the vents? No surprise either, the heater core isn't covered under warranty.
    7"
  2. #2 Re: Leaking heater core or much worse?
    being its summer take one hose off and use it to loop the coolant back to the alt bracket. this will stop the leak till you install a new core.
  3. #3 Re: Leaking heater core or much worse?
    Oct 2011
    Toledo, OH
    But it does just sound like the core is only leaking? There isn't something else that could be blowing water out the vents?
    7"
  4. #4 Re: Leaking heater core or much worse?
    Nov 2012
    Madison
    Mine went in late winter, so I was using windshield/floor. It came out kinda fuzzy and slimed up the windows pretty good.
    I would think using the vents would be about the same scenario, if not more.
    Those are the symptoms, steamy looking air/water on floorboard and level down in radiator. Your coil box probably is probably slimy on the bottom from dripping.
    80 or so for heater coil and some antifreeze. No big deal to change, especially in summer.
  5. #5 Re: Leaking heater core or much worse?
    its the only thing with coolant in it. does it smell sweet?
  6. #6 Re: Leaking heater core or much worse?
    Oct 2011
    Toledo, OH
    It just smelled like condensation like from your exhaust when you first start it. However, I'm probably running %90 water since I drained the radiator in anticipation of doing my coolant elbows and TB turndown. The stuff on the floor was sweet, but I have no idea how much crap has been spilled on it in the past.
    7"
  7. #7 Re: Leaking heater core or much worse?
    Oct 2011
    Toledo, OH
    Can I just block the hoses off?
    7"
  8. #8 Re: Leaking heater core or much worse?
    no, just loop one. your heater core flows coolant year round as you just found out. it need to circulate.
  9. #9 Re: Leaking heater core or much worse?
    Oct 2011
    Toledo, OH
    At AutoZone now getting a section of hose now.
    7"
  10. #10 Re: Leaking heater core or much worse?
    Yes it's heater core and best of luck looping them, unless you buy that new piece of hose.
  11. #11 Re: Leaking heater core or much worse?
    Oct 2011
    Toledo, OH
    Yeah I looked at the stock hoses and saw that wasn't a possibility to use them, which is why I asked if they could be closed off instead. I bought a foot of hose, cut it in half, and used a 90deg copper coupler at the bend, works out good for now.
    7"
  12. #12 Re: Leaking heater core or much worse?
    one hose is larger to the fire wall. i took that one off, and looped it. you could feel it flowing coolant.
  1. Heater Core?
    By GrandPrixgtp2000 in forum General Tech Discussion
    Last Post: 06-21-2012, 04:33 PM
  2. Oil leaking in my car getting worse :/
    By Haulero in forum General Tech Discussion
    Last Post: 06-09-2011, 06:19 AM
  3. heater core
    By PONTIACGTP05 in forum Introductions/Noob Questions
    Last Post: 04-08-2010, 10:24 PM
  4. Ze heater core
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2009, 03:23 PM
  5. 99 GTP- Leaking Heater Core
    By Juxtaghost in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2009, 02:34 PM
