Thread: Leaking coolant at tstat housing
Results 1 to 17 of 17
  1. #1 Leaking coolant at tstat housing
    Aug 2013
    arlington, tx
    So i'm leaking coolant where the upper rad hose connects to the tstat housing. It drips consistantly when I stop. I had the same issue a couple of months ago so I bought a new hose, new clamps and I cleaned the tstat housing up pretty good to make sure there was nothing preventing a good seal. Time for a new tstat housing maybe or what? 04 GP NA. Maybe just putting some jb weld or something on the inside of the end of the hose?
  2. #2 Re: Leaking coolant at tstat housing
    Feb 2013
    37.295091, -121.930053
    maybe a lose bolt or the seal for the tsat needs replacing
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Leaking coolant at tstat housing
    Aug 2013
    arlington, tx
    I'm not leaking there. It's where the rad hose and tstat housing meet. Where the clamp goes.
  4. #4 Re: Leaking coolant at tstat housing
    Feb 2013
    put a new clamp on it.
  5. #5 Re: Leaking coolant at tstat housing
    Aug 2013
    arlington, tx
    I already did that the last time I changed out the hose. I bought the adjustable one and then went back to the OEM style. The one that you squeeze the ends on.
  6. #6 Re: Leaking coolant at tstat housing
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    If you're running dexcool there's a fair chance the coolant is eating into the tstat housing. The corrosion will make it difficult for the hose to seal, even with the help of a clamp. If a new hose doesn't fix the issue, hit up the junkyard for a new tstat housing. And flush and refill with green coolant next time, if that's the case.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  7. #7 Re: Leaking coolant at tstat housing
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Quote Originally Posted by hensleya1 View Post
    Or take it off and hit it with a wire wheel. Once off, it should be pretty obvious where it needs to be cleaned up.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  8. #8 Re: Leaking coolant at tstat housing
    your putting the clamp close to the end where the lip is at the end of the t stat housing right?
    also make sure nothing is suck on the inside of the hose.
  9. #9 Re: Leaking coolant at tstat housing
    Aug 2013
    arlington, tx
    I am running dexcool. The tstat housing is fairly new, I bought it a few years ago when I lost the bleeder valve off the original one. It doesn't look corroded at all.
  10. #10 Re: Leaking coolant at tstat housing
    Aug 2013
    arlington, tx
    Quote Originally Posted by LeadfootCJ7 View Post
    Take what off? The tstat housing? It's not leaking at the tstat, only where the hose is connected to housing.
  11. #11 Re: Leaking coolant at tstat housing
    Aug 2013
    arlington, tx
    I put the clamp sort of near the middle of where the "valley" right before the lip is but not right where the lip is. Should I just move it up a little bit?
  12. #12 Re: Leaking coolant at tstat housing
    i would, thats how i put all my clamps, close to that lip, not on top of it, just a little bit from it, you'll see the hose sorta pull in around that lip when clamped.
    id also take it off and make sure its all clean still, crap breaks off sticks inside the hose sometimes.
  13. #13 Re: Leaking coolant at tstat housing
    GTP Level Member
    Aug 2012
    st louis park, MN
    Like others, I would just make sure its clean and that the clamp is in the correct location. You could put on a screw style clamp as well if there is room for it. Two clamps better than one? Weren't you having coolant leak issue around the thermostat a while back?
  14. #14 Re: Leaking coolant at tstat housing
    Aug 2013
    arlington, tx
    I'll do that this weekend and see. I'm also going to do a pressure test on the rad because I think there's a leak somewhere. On a cold start, it would leave a good amount of coolant on the floor but not on any other starts and only if I was on an even surface because my driveway is on an incline and it wouldn't do that on a cold start. Weird...
  15. #15 Re: Leaking coolant at tstat housing
    Aug 2013
    arlington, tx
    Quote Originally Posted by stocker View Post
    Thanks. I will do that saturday, not sure if I will go with 2 clamps but we'll see. Yea I was leaking coolant in the same spot maybe like a month or 2 ago but the old clamp seemed to fix the issue.
  16. #16 Re: Leaking coolant at tstat housing
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Nothing wrong with dexcool...
    Problem is with people... who leave it in too long and don't maintain cooling system LOL!
  17. #17 Re: Leaking coolant at tstat housing
    Aug 2013
    arlington, tx
    Quote Originally Posted by 231FUN View Post
    My dexcool is pretty fresh. Put it in back in February of this year. Not a bit of brown or anything so i'm pretty sure that's not the cause.
  1. Replies: 16
    Last Post: 07-14-2011, 05:44 PM
  2. Leaking coolant in my 00 gt
    By GPrixGT00 in forum General Tech Discussion
    Last Post: 06-03-2011, 12:01 PM
  3. Coolant Leaking Bad!
    By Ralphie in forum General Tech Discussion
    Last Post: 02-12-2011, 03:07 PM
  4. leaking coolant
    By pacothetaco in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2010, 11:25 AM
