Thread: seafoam in a higher mileage engine. Good or bad idea?
Results 1 to 10 of 10
  1. #1 seafoam in a higher mileage engine. Good or bad idea?
    SE Level Member mngtp's Avatar
    Crystal, MN
    Our GP just rolled 233,xxx miles. I was thinking about doing a seafoam treatment since its over due for plugs and wires. If I decide to do it, I'll probably be using the vac line under the s/c snout instead of the brake booster line unless you guys think it will be ok. From my searching, some say the brake booster line is ok, while others say to use the vac line under the s/c snout.
    But my main question is will the seafoam treatment through the vac line be a good idea for our car with so many miles? Is it going to hurt anything? I just dont want to damage anything. I already have about $700 worth of parts (junkyard parts/ used) to get and try to do myself. So I dont want to risk it if the treatment may do more harm than good. Which is why I decided to ask you guys first.
    Thanks for you opinions and input.
    HIS: 1999 Pontiac Grand Prix Coupe GTP: 245,xxx miles and counting, 4" HD intake, 17" '06 Grand Prix GTP Rims
    HERS: 2005 Chevrolet Equinox LS: stock for now
  2. #2 Re: seafoam in a higher mileage engine. Good or bad idea?
    Ask yourself, what are you trying to accomplish with it?
    Cleaner pistons?
    Cleaner intake tract?
    Ehhhhh do your oil changes.. run enough fuel through it and ....drive on.
  3. #3 Re: seafoam in a higher mileage engine. Good or bad idea?
    i used it with over 200,000 miles. she smoked like a pig.
    i used the brake booster line. did a lim job after the fact and the rotors looked fine.
  4. #4 Re: seafoam in a higher mileage engine. Good or bad idea?
    Scotty also makes my grandmother look like a race car driver
  5. #5 Re: seafoam in a higher mileage engine. Good or bad idea?
    i drive faster then she does lol
  6. #6 Re: seafoam in a higher mileage engine. Good or bad idea?
    she's dead, I sure hope you do.
  7. #7 Re: seafoam in a higher mileage engine. Good or bad idea?
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    I wasn't aware Scotty was known for driving slow
    I'm with the other posters here, though. Just do your oil changes regularly, save the ten bucks.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  8. #8 Re: seafoam in a higher mileage engine. Good or bad idea?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    In your fuel and through vac line if you want...but I would never reccomend putting the stuff in your oil/crankcase
  9. #9 Re: seafoam in a higher mileage engine. Good or bad idea?
    I've put Sea Foam in my crank case tons of times.
  10. #10 Re: seafoam in a higher mileage engine. Good or bad idea?
    Quote Originally Posted by hensleya1 View Post
    i have a commercial drivers lic. so im trying to keep it points free these days.
    trust me, ive acted a fool and caught plenty, i've racked up like 48 points on my lic over the years. all came and gone. most at one time was 18. they take it at 12 lol i was getting busy living before they took it away lol
  1. manual fan switch: good idea bad idea?
    By asite57 in forum General Tech Discussion
    Last Post: 04-22-2012, 01:15 PM
  2. Good Idea or Bad Idea?
    By Robby Avery in forum Turbo
    Last Post: 01-25-2011, 04:55 PM
  3. Good idea - Bad idea?
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 04:51 PM
  4. Seafoam Trans Tune any good?
    By 99BluGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-28-2008, 09:01 AM
