Thread: What spark plug and wires should i use??
Results 1 to 13 of 13
  1. #1 What spark plug and wires should i use??
    SE Level Member SCGT06's Avatar
    Apr 2014
    What are u guys using?? Any suggestions?? My Mods: 189 stat, 3.4 pulley, headers, intake, rocker arms..
    Sent from my GT-I9152 using Tapatalk
  2. #2 Re: What spark plug and wires should i use??
    al104's
  3. #3 Re: What spark plug and wires should i use??
    Ocala, FL
    Copper autolite 104's
  4. #4 Re: What spark plug and wires should i use??
    Agreed.
  5. #5 Re: What spark plug and wires should i use??
    Plain ol ac delco for wires
    04 Comp G.
  6. #6 Re: What spark plug and wires should i use??
    Professional grade or OE spec. None of this Delco Advantage crap.
  7. #7 Re: What spark plug and wires should i use??
    Apr 2014
    A/C DELCO IRIDIUMS are not any good then???
  8. #8 Re: What spark plug and wires should i use??
    Not when you're modded.
  9. #9 Re: What spark plug and wires should i use??
    Apr 2014
    Those are the ones i got..... so i should return them then huh?
  10. #10 Re: What spark plug and wires should i use??
    Lol modded. Car is basically stock.
    Try some stock temp cheapo coppers and see how they burn. If they burn fine, buy some AC Delco 41-101s and enjoy the fuel economy.
  11. #11 Re: What spark plug and wires should i use??
    Jan 2012
    Austin,tx
    When I changed mine I went with autolite double platinum plugs and ac delco wires.
    06 Grand Prix GT stock, 02 Mustang GT far from stock
  12. #12 Re: What spark plug and wires should i use??
    Quote Originally Posted by DreamerGT View Post
    Not to hate on you, but give em serveral thousand more miles and they will soon foul out. Waste spark ignition system eat platinum plugs alive.
  13. #13 Re: What spark plug and wires should i use??
    Apr 2011
    Vassar, Mi
    I run plain AL copper 103's and 104's. I also change them every other oil change to be sure that I have no spark plug issues. As far as wires go I have Taylor Spiro-pros from summit. They are 8mm with very durable boots that will not pull off of the cables or rip with frequent plug changes and the cable insulation is very durable also as I have accidentally had them laying directly on the headers for weeks at a time when my wire routing gets disturbed after service. They run around $50
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  1. Spark plug wires, 8mm?
    By triebenbach07 in forum General Tech Discussion
    Last Post: 12-05-2012, 11:07 AM
  2. Spark Plug Wires?
    By tcafego in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2011, 08:35 PM
  3. Spark plug wires!
    By gonzo915gp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2009, 11:14 PM
  4. spark plug wires
    By jaysongt85 in forum General Tech Discussion
    Last Post: 05-28-2009, 02:30 PM
