Thread: Spark plug wires, 8mm?
Results 1 to 13 of 13
  1. #1 Spark plug wires, 8mm?
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    I've got a friend that will be replacing plug wires this coming weekend. I know the stock wires are 7mm. I thought that I had heard somewhere that 8mm wires were readily available at part stores for an older Bonneville (96 era) Does anyone have any knowedge on this?
    Thanks
    02 sedan, top swap
  2. #2 Re: Spark plug wires, 8mm?
    The size of the wires does not matter. Run 7mm or 8mm, it makes zero difference.
  3. #3 Re: Spark plug wires, 8mm?
    Max Cook
    Guest
    ZZPs are 10.5mm but they're pretty expensive. Really good wires though.
    ZZPerformance - ZZP 10.5mm Plug Wires #ZZ-SPW-G4
    You must not of heard all the stories about Zzp and there crappy wires huh? I kno they revised them but still food for thought. Just get ac delco replacements from advance and be happy.
    04 Comp G.
  5. #5 Re: Spark plug wires, 8mm?
    Pennsylvania
    Buy cheap store brand and sleep soundly on a lifetime warranty.
    Or that.
    04 Comp G.
  7. #7 Re: Spark plug wires, 8mm?
    Autolite Pro's are readily in stock at my local parts store. And lifetime!
  8. #8 Re: Spark plug wires, 8mm?
    Max Cook
    Guest
    Yes I have. I had them before that happend and after that happend. The original ones were awesome as all hell. Then they switched to a different manufacturer and they screwed them up big time. Which is when they got a bad reputation. Now they've switched back to the old manufacturer and they're awesome again.
  9. #9 Re: Spark plug wires, 8mm?
    Dec 2012
    Texas
    thats music to my ears max cuz i just got some in yesterday! lol u notice any gains in response? mileage?
  10. #10 Re: Spark plug wires, 8mm?
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    msd or prj wires are the best
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  11. #11 Re: Spark plug wires, 8mm?
    Max Cook
    Guest
    Quote Originally Posted by freedom2104 View Post
    No idea what the gains are like. When I did it I was doing a lot of other mods that do a lot more at the same time. I know on my old car I was one of the first people to buy the original kind and they really did a lot for that car. They're definitely overkill for probably any application but they're really high quality and reliable (the good version). At least from my experience.
  12. #12 Re: Spark plug wires, 8mm?
    Dec 2010
    long prairie, mn
    thanks for all the input. the answer i was looking for is "92-94 bonneville SSEI, "1" VIN code" has the 8mm wires.
    they are actually cheaper than the "recommended" parts store wires
    ...just throwing that out there for furture reference.
    02 sedan, top swap
  13. #13 Re: Spark plug wires, 8mm?
    You do realize that you can get 8mm wires in many other brands w/o going to the supercharged L67 Series I Bonne motor? I'd be concerned about the Bonnie's fitting properly for the back set since the plug placement in the head is not symmetrical, the charger is smaller, the coil pack bracket is different and other things.. Just tossing out a little general Bonnie knowlege for ya.
    As for the gains...if your plug wires are working well, then you have no gains. If they sucked, then you'll gain back lost power.
  1. Spark Plug Wires
    By fri3dchick3n in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2011, 01:54 PM
  2. spark plug wires
    By izup69 in forum 04+ Specifics
    Last Post: 12-04-2009, 07:32 PM
  3. Spark plug wires!
    By gonzo915gp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2009, 11:14 PM
  4. spark plug wires
    By jaysongt85 in forum General Tech Discussion
    Last Post: 05-28-2009, 02:30 PM
