Thread: need help with the exhaust
Results 1 to 20 of 23
  1. #1 need help with the exhaust
    GT Level Member kyliek23's Avatar
    Feb 2013
    anyone know what i should do with my exhaust. i did a temporary fix with like 4 connectors, 6 exhaust clamps and some exhaust tape. after doing that, my car vibrates and you can here it rattle. i hate the noise and feel of my car. any ideas on what i should do, and thats cheap. looking to stay on a decent budget
    2005 Pontiac Grand Prix Base
  2. #2 Re: need help with the exhaust
    Dec 2010
    DMV
    Where is it leaking?
    Sent from my HTC One using Tapatalk
  3. #3 Re: need help with the exhaust
    Feb 2013
    not sure if it is leaking. but the vibration and noise that it makes when vibrating is what is really getting me. and thats because i have a ton of exhaust clamps on there for an easy fix
  4. #4 Re: need help with the exhaust
    Dec 2010
    DMV
    Well Easy isn't working anymore. Have you taken it to a shop?
  5. #5 Re: need help with the exhaust
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Is it like the mufflers rattling or what exactly did you fix.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  6. #6 Re: need help with the exhaust
    Nov 2012
    Madison
    Get a piece of cardboard to lay on and snap some pics.
    I am sure you will get a lot of suggestions after you post them.
  7. #7 Re: need help with the exhaust
    Feb 2013
    oh sorry didnt specify. replaced my resonator with a thrush glass pack. resonator was squished and welds broke
  8. #8 Re: need help with the exhaust
    sounds like your not using the rubber hangers at this pint by the cat. i wired mine up for a temp fix and my god did it vibrate bad.
  9. #9 Re: need help with the exhaust
    Quote Originally Posted by spazzz View Post
    This.
    Mine rattles slightly but not having a exhaust hanger welded onto the headers anymore will do that.
    04 Comp G.
  10. #10 Re: need help with the exhaust
    Feb 2013
    <a href="http://s1284.photobucket.com/user/Kylie_Mae_Krueger/media/20140618_195147_zps741fc997.jpg.html" target="_blank"><img src="http://i1284.photobucket.com/albums/a579/Kylie_Mae_Krueger/20140618_195147_zps741fc997.jpg" border="0" alt=" photo 20140618_195147_zps741fc997.jpg"/></a>
  11. #11 Re: need help with the exhaust
    Feb 2013
    cant post a picture. so follow the link
  12. #12 Re: need help with the exhaust
    use [img] tags.
    magic:
  13. #13 Re: need help with the exhaust
    Feb 2013
    tried everything. wont work
  14. #14 need help with the exhaust
    Post the IMG tag but Matt got it posted for you
    04 Comp G.
  15. #15 Re: need help with the exhaust
    i called it. your hanger is bolted to the floor and right to the pipe. thats all the racket you hear.
    you need to take them off and then weld a rod to the pipe where it will fit the rubber hanger that mounts from under the car.
  16. #16 Re: need help with the exhaust
    Feb 2013
    haha. wow. im a little slow. thanks
  17. #17 Re: need help with the exhaust
    Edit: nvm ninja'd
    04 Comp G.
  18. #18 Re: need help with the exhaust
    Feb 2013
    haha well thats what my exhaust looks like on the back end of the res. looks the same the beginning of res
  19. #19 Re: need help with the exhaust
    if the floor part and rubber hanger are still there parts stores sell a clamp style rod.
    then they sell a rubber strap you bolt to under the car and clamp the pipe to it. it has a bunch of holes to use for adjustments.
    in this pic of my old and new pipes side by side, you can see the old one has a clamp on rod in the same place as the new one's welded on rod. mine rusted off lol
  20. #20 Re: need help with the exhaust
    Edit: nvm ninja'd
    ha ha got ya!
  1. Magnaflow exhaust vs zzp exhaust.
    By 01GT guy in forum General Tech Discussion
    Last Post: 02-13-2014, 11:12 PM
  2. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  3. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
