Thread: a/c hose install onto the compressor
Results 1 to 1 of 1
  1. #1 a/c hose install onto the compressor
    Nov 2008
    Houston
    I just replaced the suction / dicharge a/c hose on my 02 grand prix. The manifold that fits onto the compressor came with 2 orings installed onto the nipples that go into the compressor. The original hose manifold i took off did not have any rubber o rings, but had a washer on each side. I tried installing without the washers and just the o rings that came with it and it leaked. I then installed it again with the metal washers and it still leaks. do i need to install with the orings and the washers and if so what order do they go on? washer first and then o ring or vice versa?
    This is the part i replaced.
    http://i.ebayimg.com/00/s/NTAwWDUwMA==/z/jRkAAOxycD9TTeFG/$_12.JPG
  1. Looking for a Hose
    By demonadark in forum General Tech Discussion
    Last Post: 09-02-2013, 07:38 PM
  2. Spring install without an air compressor???
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2012, 08:36 AM
  3. A/C compressor hose has a hole in it...
    By selym17 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-09-2012, 06:11 AM
  4. What hose is this???
    By jwjones in forum General Tech Discussion
    Last Post: 02-18-2012, 01:27 AM
  5. What hose is this?
    By dirtmaster88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 06:10 PM
