Thread: Bluetooth OBD2 Scan tool??
Results 1 to 10 of 10
  1. #1 Bluetooth OBD2 Scan tool??
    SE Level Member ItaliaGTP35's Avatar
    Jul 2013
    Chicago IL
    So has anyone used one of these to monitor everything going on? From what I found and researched I found the BAFX one seems to be the best working one on the market. Also the torque app does everyone use the lite or pro version? That may be a dumb question because the pro looks way better with more readings. Thanks in advance for all input.
    Sent from my HTCONE using Tapatalk
  2. #2 Re: Bluetooth OBD2 Scan tool??
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Pro verison and the 12 buck adapter thats all you need I'll grab a link in a sec
    Blamo: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    I have that exact one and it hasn't put up a fuss yet.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: Bluetooth OBD2 Scan tool??
    Jul 2013
    Chicago IL
    I have a buddy that has that one and he hates it it's always falling out granted he doesn't have a gp but none the less I'm gonna give the bafx a shot and I'm going with the pro version as well
  4. #4 Re: Bluetooth OBD2 Scan tool??
    Apr 2012
    Dayton, OH
    I used mine on a car with a downward facing OBD port and it never fell off it was always really snug.....also btw the bafx one is probably gonna be too long and your gonna hit it on your leg. Your buddy must have broke his somehow because they shouldn't be that loose period. But not my money do as you wish.
    2012 F150 STX
  5. #5 Re: Bluetooth OBD2 Scan tool??
    Mines as big as that Bafx one and my leg doesn't hit it on my gp. Now my Accent I had a 5 speed and would hit it all the time when using the clutch.
  6. #6 Re: Bluetooth OBD2 Scan tool??
    I break stuff selliott's Avatar
    Kansas City
    I use torque pro and a cheap Bluetooth obd works great
  7. #7 Re: Bluetooth OBD2 Scan tool??
    I bought mine on ebay way back in like 2010. I paid $35 for the adapter and it took like 2 weeks to get here from China.
  8. #8 Re: Bluetooth OBD2 Scan tool??
    Kansas City
    Quote Originally Posted by Slick2500 View Post
    I did the same thing
  9. #9 Re: Bluetooth OBD2 Scan tool??
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    I have torque pro too and I like it. How accurate would you guys say it is? Obviously the horse power ratings and things like that aren't correct but how about the IAT and MPG?
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  10. #10 Re: Bluetooth OBD2 Scan tool??
    Feb 2013
    Missouri
    IAT's are accurate, because they are sourced from the PCM's sensor readouts. MPG I hear is relatively accurate (more than the DIC if that's saying anything), but it is more accurate if you select enhanced MPG calculations in the Settings->OBD adapter section. Make sure you select Fast Communication while you are in there. That'll speed things up a bit.
  1. Security light came on when I plugged in bluetooth obd2 adapter.
    By iowagtp in forum General Tech Discussion
    Last Post: 09-23-2013, 11:53 PM
  2. Bluetooth obd2 and Android
    By rperry435 in forum Audio, Security & Visual Electronics
    Last Post: 11-17-2012, 01:29 AM
  3. ABS Scan tool??? Please help!
    By craig1980 in forum General Tech Discussion
    Last Post: 12-01-2011, 10:58 PM
  4. scan tool
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2011, 12:48 PM
  5. Bluetooth OBD2 Scanner
    By Jackd90 in forum Audio, Security & Visual Electronics
    Last Post: 02-26-2011, 10:08 AM
