IAT's are accurate, because they are sourced from the PCM's sensor readouts. MPG I hear is relatively accurate (more than the DIC if that's saying anything), but it is more accurate if you select enhanced MPG calculations in the Settings->OBD adapter section. Make sure you select Fast Communication while you are in there. That'll speed things up a bit.
