Thread: Really squeaky wheel
Results 1 to 13 of 13
  1. #1 Really squeaky wheel
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    My front drivers side wheel is making a horrible squeak sound while driving. At least I'm thinking it's the wheel since it does it in time with the speed of the car. It does it up until about 30 mph and worse at slower speeds like going through a parking lot. It started to do it once it got warm outside after the winter. Anyone have any ideas?
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  2. #2 Re: Really squeaky wheel
    Feb 2013
    37.295091, -121.930053
    needs lube on that site
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Really squeaky wheel
    check your brake caliper slider pins, re grease em. seems like they are dragging.
    before you take the wheel up tho, jack the wheel up, lugs tight, then push and pull the top of the tire, you can also watch the rotor, if it moves, or you feel the wheel move, the hub is bad.
  4. #4 Re: Really squeaky wheel
    Jan 2014
    AR
    Jack it up, check for a loose wheel bearing. Visually inspect the brake. Still found nothing? Disassemble the brake. Still nothing? Probably the hub gone bad and its noisy but not loose.
  5. #5 Re: Really squeaky wheel
    Buffalo, NY
    I was thinking it was probably the breaks or wheel bearing but was wondering if anyone had other more likely suggestions. Should wheel bearings be changed in pairs or just when one goes? And would i need an alignment after?
  6. #6 Re: Really squeaky wheel
    Jan 2014
    AR
    Replacing just one hub is fine if thats what it is. No alignment needed if the bearing was still good at the last alignment.
  7. #7 Re: Really squeaky wheel
    buy one with a 3 year warranty, then when the other side goes bad, and it will. use the warranty for a free hub. did i say that out loud? shhhhhhhhhhhhh
  8. #8 Re: Really squeaky wheel
    Buffalo, NY
    Alright well i just did the struts and I'm doing the outer tie rods and LCAs this weekend. So I should try and replace this hub before getting the alignment done then?
  9. #9 Re: Really squeaky wheel
    Buffalo, NY
    haha I love this idea
  10. #10 Re: Really squeaky wheel
    ive done it. and ill be doing it again soon i think, somethings up with my left front wheel, low trac light flashes for no reason over bumps, and the car feels like its being held back on the left side and pulling a bit to the left. abs light also comes on, yet all the hubs are tight. i need a scan.
  11. #11 Re: Really squeaky wheel
    Buffalo, NY
    Ya I'm not having any of the problems you've mentioned just a really loud annoying squeak. So if I buy one with a warranty and bring back the other side when it goes they don't check to see if it's the correct part? Or are they all pretty much the same whether they're stock or a aftermarket replacement?
  12. #12 Re: Really squeaky wheel
    They can't tell one from this next.
  13. #13 Re: Really squeaky wheel
    Apr 2013
    Grand Rapids, MI
    Take a look at the lower backside of your rotor. There is a thin piece of metal that is just barely touching the rotor. Bend it back away from the rotor just a tad and I bet your squeak goes away. My GXP did the same thing. Most annoying squeak at low speeds. Bending that tab fixed it.
  1. Squeaky seat
    By traildog in forum General Tech Discussion
    Last Post: 01-24-2014, 11:12 PM
  2. Squeaky Steering Wheel
    By biggd1980 in forum 04+ Specifics
    Last Post: 07-20-2013, 06:37 AM
  3. Squeaky noise from front passenger wheel...
    By 06GXPGAL in forum Brakes/Suspension/Chassis
    Last Post: 05-17-2013, 09:48 PM
  4. Squeaky squeaky
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2011, 12:52 PM
  5. Squeaky Belt, HELP!
    By Pokey in forum General Tech Discussion
    Last Post: 05-27-2008, 08:17 AM
