Thread: Change Oil on dic
Results 1 to 5 of 5
  1. #1 Change Oil on dic
    Jan 2013
    Iowa
    I have an 08 base and I recently changed the oil. After I changed the oil, the dic says "Change Oil" every time the key is turned on. it also says that oil life is at 0%. I reset it but the message keeps coming back. I also disconnected the battery for a while and that didn't help either. Any ideas on what's up? Thanks in advance.
  2. #2 Re: Change Oil on dic
    Nov 2011
    NY
    How did you reset it?
  3. #3 Re: Change Oil on dic
    SWPA
    Disconnecting the battery won't reset it. You need to cycle through the DIC until it says Reset Oil Life Monitor. You can also turn the key to the on position (not start) and press the gas pedal 3 times in succession.
  4. #4 Re: Change Oil on dic
    Jan 2013
    Iowa
    The pressing of the gas pedal got it to reset. Thanks for the advise!
  5. #5 Re: Change Oil on dic
    GTP Level Member
    Aug 2012
    st louis park, MN
    The other way to do it is have the car in park and cycle through the DIC menu on the "i" button (information). One of the screens will say something like "reset oil life monitor system (->)". Press and hold the arrow DIC button for a few seconds and it will reset.
  1. Transmission fluid change, Dealership or Typical Oil Change place?
    By bjornbjorn in forum General Grand Prix Discussion
    Last Post: 09-20-2013, 10:38 PM
  2. Tools/Materials needed for trans fluid change and filter change
    By JDrach in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 07:47 AM
  3. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  4. Tranny Fluid - To change or not to change.
    By midrange in forum General Tech Discussion
    Last Post: 02-15-2012, 11:44 AM
  5. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
