Thread: Can I keep my HUD?
Results 1 to 20 of 27
  1. #1 Can I keep my HUD?
    SE Level Member Drifty's Avatar
    Jun 2010
    Fort Worth Texas
    Hey guys, so I'm gathering all my information for the l67 swap into my 95 GTP and I was wondering if I could keep my HUD or would I have to swap it from the donor? Also, can I use my information center or do I need to swap that as well?
    '95 GTP
  2. #2 Re: Can I keep my HUD?
    Donating User Odi's Avatar
    Chicago South Suburbs
    Can't answer that question, but I can point you towards w-body.com they have a large amount of info on the older GP's.
  3. #3 Re: Can I keep my HUD?
    I "think" the HUD is body control feature, I can't say for sure that it'll still work but I'd like to think it would.
  4. #4 Re: Can I keep my HUD?
    Jun 2010
    Fort Worth Texas
    Thanks odi, as to your answer five finger, i take it there is a body control module that operates outside of the pcm?
  5. #5 Re: Can I keep my HUD?
    Dec 2012
    troll land
    Theres no bcm on an 88-96 gp. And you can run ANY 88-03 w hud without a bcm. I have an 02 gp hud in my 97 monte
  6. #6 Re: Can I keep my HUD?
    Power, ground and VSS signal I assume.
  7. #7 Re: Can I keep my HUD?
    Dec 2012
    troll land
    And a few other wires too, not a big deal. On a dic however, youll need a 96 gp only unit. 97+ is bcm controlled(why i dont brag about a dic swap lol) and 95 and earlier are obd1. Have fun finding a 96 dic, ive been looking over a yr lol
  8. #8 Re: Can I keep my HUD?
    Jun 2010
    Fort Worth Texas
    I believe I am OBD1.5 :/
  9. #9 Re: Can I keep my HUD?
    Jun 2010
    Fort Worth Texas
    Sorry... but I'm guessing dic is my info center??
  10. #10 Re: Can I keep my HUD?
    dic - driver information center.
  11. #11 Re: Can I keep my HUD?
    Dec 2012
    troll land
    Obd1.5 is actually a misconception. On ur car you have an obd1 pcm and an obd2 style connecter. Only camaros and some trucks got obd1.5
  12. #12 Re: Can I keep my HUD?
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    Quote Originally Posted by l67ss View Post
    That's the very definition of an OBD1.5. It's a bastardization between the older computer, and newer ALDL connector, thus why you have to find an OBD1.5 specific scanner in order to retrieve any codes.
    That being said, what FFDP listed is all you need to make a HUD work. In fact, the HUD units themselves for the '97 - '03 are identical to the '94 - '96. Just a couple wires that need to be switched around on the harness, and you could make a newer one work right now.
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  13. #13 Re: Can I keep my HUD?
    Jun 2010
    Fort Worth Texas
    Thanks for the clarifications!
  14. #14 Re: Can I keep my HUD?
    Jun 2010
    Fort Worth Texas
    Is it even worth switching out the dic? Will it function fully??
  15. #15 Re: Can I keep my HUD?
    Dec 2012
    troll land
    If you can find a 96 dic, yes. Big if tho
  16. #16 Re: Can I keep my HUD?
    Jun 2010
    Fort Worth Texas
    Thank you for your help fellas
  17. #17 Re: Can I keep my HUD?
    It might help to take a look at the adding a hud how to threads. As mentioned, all the wiring going to a hud before 04 was analog except for the radio. I believe that was data.
    There's a 97-03 hud in my 00 Regal.
  18. #18 Re: Can I keep my HUD?
    The speed signal looks to be very much a PWM signal.
    Though it does just piggy back onto the speedometer signal from the PCM.
  19. #19 Re: Can I keep my HUD?
    Jun 2010
    Fort Worth Texas
    Thanks BillBoost. You have been a big help even back from the Bonneville forum.
  20. #20 Re: Can I keep my HUD?
    Dec 2012
    troll land
    Pwm?
