Thread: (SOLVED) Car Wont Start
Results 1 to 14 of 14
  1. #1 (SOLVED) Car Wont Start
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    So I wanted to clean the throttle body a little bit so I took the air filter off an everything to get to the throttle body, then a neighbor came over to tell me I had to move out from the grass, so not thinking anything of it, I tried starting the car an it started but died. Then I hooked everything back up and now it still wont start. What could I possibly of messed up for the car to not start?
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  2. #2 Re: Car Wont Start
    St. Louis
    Did you reconnect the MAF?
  3. #3 Re: Car Wont Start
    Jan 2012
    Sturgis, MI
    I never needed to disconnect it, I mean it was just a simple take the air filter an tube out an spray the screen a little bit.
    Miles: 170-XXX
    Engine: 3.8L V6
  4. #4 Re: Car Wont Start
    depending on what you sprayed in the TB maybe you killed the maf. un plug it then try to crank it over.
  5. #5 Re: Car Wont Start
    Jan 2012
    Sturgis, MI
    Trying to unplug seems impossible because its likes its stuck and I feel like im gonna really mess things up. Is it suppose to be a little rough to unplug?
    Miles: 170-XXX
    Engine: 3.8L V6
  6. #6 Re: Car Wont Start
    Jan 2012
    Sturgis, MI
    Nevermind I got it lol just did yes
    Miles: 170-XXX
    Engine: 3.8L V6
  7. #7 Re: Car Wont Start
    just lift the locking tab with your finger a bit, then wiggle it off.
  8. #8 Re: Car Wont Start
    Jan 2012
    Sturgis, MI
    Well all i really did was let it sit for about half an hour and after a friend showed up. She started right up. The problem was just too much air from trying to start it with everything that was taken off. I wasnt thinking right an was too busy thinking about getting out of the grass. Shes good now. Thanks as always GPF.
    Miles: 170-XXX
    Engine: 3.8L V6
  9. #9 Re: (SOLVED) Car Wont Start
    having the air filter off should in no way keep it from running. a open cone air filter is almost like having no filter, and lots of us run them with no issues.
  10. #10 Re: (SOLVED) Car Wont Start
    Jan 2012
    Sturgis, MI
    Then i cant really think of why it didnt wanna start but after sitting for a bit, it started it. I mean i did what you said with the maf sensor, then plugged it in and let the car sit for awhile then after all that, it started with no hesitation.
    I really need to learn some mechanics, i feel like such a dumb ass every time i get on this forum.
    Miles: 170-XXX
    Engine: 3.8L V6
  11. #11 Re: (SOLVED) Car Wont Start
    maybe the maf was wet still, or it got flooded from the tb cleaner, who knows, as long as it fired up.
  12. #12 Re: (SOLVED) Car Wont Start
    Jan 2012
    Sturgis, MI
    Yeah but i never got around to spray anything because the guy had already came by an said i had to move, there was no liquid near that maf sensor.
    Miles: 170-XXX
    Engine: 3.8L V6
  13. #13 Re: (SOLVED) Car Wont Start
    well thats just real odd.
    theres really no such thing as to much air. assuming you got a 97-03 with the maf in the TB.
    04 + has the maf in the air filter tube, it may fight to fire up if its not hooked up in a 04+.
  14. #14 Re: (SOLVED) Car Wont Start
    Jan 2012
    Sturgis, MI
    Yeah I have a 98. I dont know man, but shes still doing real good. Thanks again as you replied to another issue/question I had and have had. Im such a rookie.
    Miles: 170-XXX
    Engine: 3.8L V6
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. Topped swapped 06 GP now wont start and scan tool wont comm with ECM
    By jbrltoliver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-31-2013, 08:36 AM
  3. car wont start
    By bmx6454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-11-2012, 09:45 AM
  4. 98 Gtp wont start
    By qwiver1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 11:15 PM
  5. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
