Thread: Fresh oil change, 1000 miles and low oil level light already?
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: Fresh oil change, 1000 miles and low oil level light already?
    GTP Level Member
    Aug 2012
    st louis park, MN
    I only have a couple small things to add. With 90k miles I do not think your engine should be burning this much oil due to "wear". I think something else is going on - 1 quart in 3,000 miles would be more normal.
    Can you say for sure if this is the first time you've had so much oil loss? I'm just throwing out that you could change your PCV valve since they are only like $5. I don't recall why, but I think I remember reading this can relate to oil loss/burn.
    I was going to say if this is your first synthetic oil change, switch back to conventional you said it has always been on synthetic ...
  2. #22 Re: Fresh oil change, 1000 miles and low oil level light already?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I agree with stocker, unless the car was running synthetic before change back over.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  3. #23 Re: Fresh oil change, 1000 miles and low oil level light already?
    Mar 2014
    PA
    As far as I know the car was always run with synthetic, or I was told. Assuming that it WASN'T, can anyone elaborate on "switching back" to regular motor oil?
  4. #24 Re: Fresh oil change, 1000 miles and low oil level light already?
    Apr 2012
    Dayton, OH
    Drain synthetic oil, refill with conventional with new filter or at least I would put a new filter on. I would look it up but something about synthetic just being different and can leak from places it wouldn't normally. Or I'm completely wrong
    2012 F150 STX
  5. #25 Re: Fresh oil change, 1000 miles and low oil level light already?
    if its eating that much oil stop paying for synthetic oil, maybe use some 10 w40 see if it eats it too.
    pcv should be checked if it has not been.
    ever use seafoam? maybe give that a shot, just maybe the oil rings are caked shut and causing the consumption.
  6. #26 Re: Fresh oil change, 1000 miles and low oil level light already?
    Just switch, aint nothing special about changing oils.
    Shoot, I mix and match oils all the time, even at work sometimes lol. If I run out of 5w30, just mix in some 5w20 and it's all good in the hood.
  7. #27 Re: Fresh oil change, 1000 miles and low oil level light already?
    Pennsylvania
    It always gets me when my customers freak about whether oils are synthetic or not, and all the conspiracy theories about synthetic oils ruining motors. They're totally compatible with conventional.
    This idea that you cant switch back and forth is just nonsense, and the idea that synthetics cause leaks is misguided.
    Synthetics are just really really good at cleaning, so when you take a higher mileage motor that's been run on conventional all it's life with medium to long oil change intervals, you have gunk that's built up in place of gaskets that have worn away. What happens when you add the super-cleany synthetic? It washes all that gunk out and cleans everything up, now there's no more gunk plugging up those cracks in the gaskets from the inside. They also tend to be easier flowing than conventionals, so there's that too.
    Sport Edition Kv5 18x8
  8. #28 Re: Fresh oil change, 1000 miles and low oil level light already?
    Well said.
  9. #29 Re: Fresh oil change, 1000 miles and low oil level light already?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by FriboRage View Post
    So if the synthetic didn't cause the leaks, what did?
    I never recommend synthetics or cleaners on hi-er mileage engines. The outcome can be good, but most of the time it is horrible.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. Drove 1000 miles straight, car is making awful noises now
    By calvin in forum General Tech Discussion
    Last Post: 04-14-2011, 06:57 PM
  3. How do you change your member level?
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 08-15-2010, 12:16 AM
  4. fresh blower, fresh wash, fresh ccfl's =]
    Last Post: 06-10-2010, 12:37 PM
