Thread: Warning Light Central, Has anyone seen this?
Results 1 to 10 of 10
  1. #1 Warning Light Central, Has anyone seen this?
    Apr 2014
    Monroe MI
    Please see 30 second video here: http://www.screencast.com/t/33CpbRtlw
    I know for a fact the car needs rear hubs, started getting the abs, stablity, traction errors so i ordered 2 new rear hubs.
    Today seems to have progressed to more warning lights.
  2. #2 Re: Warning Light Central, Has anyone seen this?
    Enfield, CT
    Dude, That sucks man. I would get a starting & charging evaluation at a local pep boys and go from there.
  3. #3 Re: Warning Light Central, Has anyone seen this?
    SE Level Member A98GTP's Avatar
    Apr 2014
    Texas
    Definitely need to scan and clear codes just for a fresh start wow that's a Christmas tree in there.
  4. #4 Re: Warning Light Central, Has anyone seen this?
    Over half that could just be a wheel speed sensor wire has been damaged.
  5. #5 Re: Warning Light Central, Has anyone seen this?
    Oct 2011
    Canada
    MY compG had traction abs and stability lights, and my scanner read a right from wheel sensor circuit issue. It was the wiring to a speed sensor. i replaced the hubs and nothing. after that i followed the wire and found that it frayed. Fixed it and no more lights
    Damn matt beat me to it.
    04 CompG - Spectre Intake
    11 5.0 Mustang GT - Stock
  6. #6 Re: Warning Light Central, Has anyone seen this?
    Apr 2014
    Monroe MI
    Right after i posted tried to start the car again and it would not start (No Turnover at all) but the needles on the dash did their normal movement like on start. I think its a combo of bad hubs and alternator. Installing 2 rear hubs, alternator w new pigtail & battery. Will let everyone know how it goes. I will check for frayed wired thanks for the advice. If all that dont work im gunna check for bad grounds too, had an aftermarket audio system put in about 3 weeks ago, maybe they jacked something too but you would think bad wiring job would rear its head right away not 3 weeks
  7. #7 Re: Warning Light Central, Has anyone seen this?
    Apr 2014
    Monroe MI
    HighOctaneRacing, That was a good idea until i couldnt start the car again I got 2 rear ABS hubs, battery, alternator & pigtail for 315 after cores....seems like a good deal.. The Stealership wanted over a G for all.
  8. #8 Re: Warning Light Central, Has anyone seen this?
    Apr 2014
    Monroe MI
    Haven't changed the hubs yet but replaced the alternator and battery. All errors went away except "Charging System Failure"; think the pigtail was frayed. New pigtail still waiting to get delivered. Will update y'all once pigtail is on. Belt Tensioner was pain in the arse till i found the pipe clamp trick http://ls1tech.com/forums/ls4-perfor...tine-belt.html
  9. #9 Re: Warning Light Central, Has anyone seen this?
    Good to hear it's all working out for ya so far.
  10. #10 Re: Warning Light Central, Has anyone seen this?
    Apr 2014
    Monroe MI
    After a 2 day debacle with 3 mis-packaged pigtails. Finally got the Christmas tree lights packed away. If i had to narrow it down to one major culprit i was the alternator and burned out pigtail. Most likely just the pigtail arcing on the alternator mount from frayed wire. Would have been nice to have testing equipment but hey sometimes its fun to tear stuff apart.
  1. Help with odd warning light combo
    By atmorrisjr in forum General Tech Discussion
    Last Post: 09-01-2013, 10:48 AM
  2. Low Coolant Warning Light
    By cutiger80 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-26-2011, 11:19 PM
  3. Oil warning light
    By Skrappi69 in forum General Tech Discussion
    Last Post: 04-04-2011, 05:24 PM
  4. warning light
    By theextreem in forum Shops and Community Heroes
    Last Post: 03-06-2010, 02:01 PM
  5. ABS warning light
    By BankRupt in forum General Tech Discussion
    Last Post: 07-15-2008, 12:48 AM
