Thread: Car problems Leaning/richening
Results 1 to 20 of 20
  1. #1 Car problems Leaning/richening
    My 04 comp g will lean out hard enough to max out my wb and the car will bog down really bad when it does it. At WOT it'll max out my wb rich. Even leaning it out via my maf won't make it come out of it. I've tried a new maf and injectors neither help at all. Any help would be appreciated. Thanks.
  2. #2 Re: Car problems Leaning/richening
    Once you get HPT and license your car, I can look.
    But it would be wise to flash the STOCK tune back into the car first, because then you have something to go back too. You also have to pretty much start over with HPT, you don't want to start "modding" a already changed tune.
  3. #3 Re: Car problems Leaning/richening
    I flashed a stock tune back to it and it made no difference.
  4. #4 Re: Car problems Leaning/richening
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Flash a stock tune with only the necessary things like the correct injector tables and maf tables flashed. Then do a data log including wideband so that a few of us on the forums here can take a peek at what its doing. My guess is it is either tune, maf, or fuel system related. But you could also have a vacuum leak.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  5. #5 Re: Car problems Leaning/richening
    I'm leaning toward vacuum leak somewhere. I flashed a stock tune to it with no difference.
  6. #6 Re: Car problems Leaning/richening
    Ok so if I'm idling and pump my brakes my car leans all the way out. Wtf is going on here?
  7. #7 Re: Car problems Leaning/richening
    Normal.
    Yes. As you pump the brake pedal you are using the vacuum stored in the brake servo. This vacuum is created by the engine in the inlet manifold. To maintain the vacuum in the servo, the air introduced by pumping the brake pedal passes down a pipe to the inlet manifold, thus leaning the mix to the engine breifly, causing the idle speed to increase till the vacuum is re-established.
    And you are cammed, it's going to have a bigger affect.
  8. #8 Re: Car problems Leaning/richening
    It's never done it before though
  9. #9 Re: Car problems Leaning/richening
    Apr 2011
    South Dakota
    You could actually very possibly have a bad brake booster. Unhook the line and plug it so you dont have a massive leak. See if your problems persist (Obviously be VERY FUXKING CAREFUL... Your brakes will be VERY hard to press)
    I love Decker<3
  10. #10 Re: Car problems Leaning/richening
    I'll try that. I'm getting about 15ish in hg at idle so I'm not sure if that's really that low or not.
  11. #11 Re: Car problems Leaning/richening
    That made no difference. I'm gonna swap the o2 tonight
  12. #12 Re: Car problems Leaning/richening
    Feb 2009
    flintnasty MI
    Flashing a stock tune will make it run about %28 too rich.
  13. #13 Re: Car problems Leaning/richening
    I'm back on my normal tune now
  14. #14 Re: Car problems Leaning/richening
    o2 made no difference.
  15. #15 Re: Car problems Leaning/richening
    Kind of a guessing game here.
    If and when you set up your HPT, you can data log various things. You can log both the pedal postion sensor and throttle body %, I think. Watch fuel trims and MAF data for volts and hz. No idea if bad injector data is causing this issue.
  16. #16 Re: Car problems Leaning/richening
    I've already checked just about everything I can think of. My throttle position is about 6 at idle I'm not sure if that's normal or not
  17. #17 Re: Car problems Leaning/richening
    Apr 2011
    South Dakota
    Time for a new Wideband o2
  18. #18 Re: Car problems Leaning/richening
    Wideband is brand new
  19. #19 Re: Car problems Leaning/richening
    Apr 2011
    South Dakota
    If the car is running fine and your fuel trims are good nothing is wrong.
    I love Decker<3
  20. #20 Re: Car problems Leaning/richening
    The car isn't running fine
  1. Richening up WOT afr with Dhp
    By dsmuts in forum PCM Tuning
    Last Post: 06-24-2013, 11:31 PM
  2. Engine leaning?
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 10-11-2012, 06:13 PM
  3. VSS problems
    By diehl2 in forum General Tech Discussion
    Last Post: 08-10-2012, 05:49 PM
  4. Is it just me? CAI problems
    By crzystve42 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2012, 12:04 PM
  5. gtp problems
    By twinturbogto in forum General Tech Discussion
    Last Post: 03-11-2010, 10:36 PM
