Is kuntzie or the guy with the Incredihoppidy 5 speed build or anyone who's done the 5 speed swap left on here. I have a question as far as what brackets from what car to use for the clutch pedal.
Thanks
Kuntzie has a 5 speed build if I remember well.
hi yes
Alright sweet your still active on here. So anyways I have compiled a list of all the parts I need for the swap from your post on w-body forum and a couple other forums and so far this is what I have
-284 getrag transmission (Including master/slave cylinders, pressure plate, clutch disk, throw out bearing, jack shaft, ect)
-Pedal Bracket from 1st gen w body (modified)
-(2) 97 SE/GT drivers side axles
-3800 camaro flywheel machined to .840
-BOLTS
-5/16"-18 3/4" length.. grade 8 these are for the flywheel
-M8 x 1.25 18mm length.. grade 10.9 these are for the pressure plate.
If you could let me know if i'm missing anything that would be awesome.
I know you ran the SPEC clutch but I'm planning on putting this in an unmodified N/A DD car. From what I gathered from the Fiero community I can just use the stock 284 pressure plate and clutch.
What is the hardest part. It seems like custom fabricating the clutch pedal mounting bracket and getting it and the master cylinder mounted are gonna be the biggest PITA. From what I could see in Kuntzies swap thread it looked like swapping the actual tranny and the axles is an in and out bolt up deal like it was meant to go there.
Another question I had was if I was to go with a 282 instead of a 284 does anybody know if I would still use all the same parts for the swap except obviously the clutch master/slave cylinders since the 284 has that wierd clutch system.
last one i saw for sale was 1200.00 and that was like 2 years ago.
crazy thing is i know where one is now. my friends brothers garage, its a Beretta z24 we are supposed to get back up running and then sell. when they parked it like 15 years ago the clutch quit working. its been garage kept the whole time too.
Its not a 284 if its from a Beretta. You don't need custom mounts for a 284 although you do need to mod the subframe. Like everyone says, good luck finding a good 284, I'm thousands deep in just the trans in my car.
No I don't have a 284 tranny right now. I know a guy who has one in a fiero (It is a 284 not a 282) with a overheated N* who will sell it for 800 if I pull it. My other thought was to use a 282 transmission until i can find a 284 in a junkyard (if thats even possible). But i only want to use a 282 if it would use the same axles, and clutch pedal bracket so that way when i find a 284 i can just swap it in without having tear the dash out all over again and then try to figure out what axles fit on top of that.
I know the 282 is not nearly as strong but i'm not at all abusive to my vehicles so hopefully it would hold up for a decent amount of time.
My research into the f23 led me to beleive that It would need custom length welded axles which I didnt want to do. If this was not the case i would LOVE to do the f23 being that parts are still available for it and it's not that hard of a transmission to find.
The hardest part of doing an f23 swap would be that I can't find a documented case of the swap being done into a 2nd gen w body. I suppose its the same as doing a fiero the only differences would be the axles used and reprogramming the pcm for the VSS. I guess somebody has to pioneer it. Lol. I guess i will start doing some more research into the f23 swap.
Yeah if i need custom axles then i'll just wait for a 284. I really am hopeing to find one in a pull-a-part type junkyard where all the prices are the same so I can get all the stuff for 250 bucks instead of paying 800 for just the tranny and I'm a little worried about buying one that was behind a northstar as i'm sure it's been abused.
