Thread: Why would more pressure be applied to one brake rotor?
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Why would more pressure be applied to one brake rotor?
    Banned
    Dec 2013
    Indiana
    Do I really need to bleed all of them again? I used all of the fluid.......DANGIT!
  2. #22 Re: Why would more pressure be applied to one brake rotor?
    if you pump the pedal 5 to 10 times, then crack each wheel just once, you'll know if theres air on the first try.
    with the soft pedal (if its air in the master) it could have been pushing air into the lines and it could be trapped.
    i use a clear tube on the end of the bleeder nipple to a bottle to keep things clean.
    i also made a one man bleeder, tube and a bottle, but that way uses a lot of fluid, (wastes it)
  3. #23 Re: Why would more pressure be applied to one brake rotor?
    Banned
    Dec 2013
    Indiana
    That's what we'll try in a few. Pump 8 times and hold pressure on the pedal, correct?
  4. #24 Re: Why would more pressure be applied to one brake rotor?
    Banned
    Dec 2013
    Indiana
    Then crack and close the bleeder?
  5. #25 Re: Why would more pressure be applied to one brake rotor?
    correct. pump the pedal, crack the bleeder, the pedal pusher holds the pedal to the floor till you make the bleeder tight, then he can re pump them.
  6. #26 Re: Why would more pressure be applied to one brake rotor?
    Banned
    Dec 2013
    Indiana
    I'll be danged......there WAS air in them lines......Pedal is 50% harder now, but, still feels more squishy then I think it should....
  7. #27 Re: Why would more pressure be applied to one brake rotor?
    that could be the rest of the air in the lines to the calipers.
  8. #28 Re: Why would more pressure be applied to one brake rotor?
    Banned
    Dec 2013
    Indiana
    I'm going to have to get more fluid tomorrow.......
  9. #29 Re: Why would more pressure be applied to one brake rotor?
    Banned
    Dec 2013
    Indiana
    Thanks for the help Scottydoggs!
  10. #30 Re: Why would more pressure be applied to one brake rotor?
    any time. ive been there with my back to the wall scratching my head before . its no fun sometimes.
  11. #31 Re: Why would more pressure be applied to one brake rotor?
    Banned
    Dec 2013
    Indiana
    That's why I signed up here! I figured you guys have been there done that!
  1. Brake Rotor Choice
    By Comanche1959 in forum Brakes/Suspension/Chassis
    Last Post: 11-24-2012, 11:53 PM
  2. 2004 Grand Prix rear suspension squeeks while brake applied
    By eriklynden in forum Brakes/Suspension/Chassis
    Last Post: 06-06-2012, 09:48 AM
  3. brake pedal jumps when applied
    By tipatalon in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2011, 06:17 PM
  4. Brake Rotor Question
    By SNeitzel in forum General Tech Discussion
    Last Post: 10-01-2010, 12:21 PM
  5. brake rotor.
    By grand2000prixgtp in forum Brakes/Suspension/Chassis
    Last Post: 09-24-2009, 02:32 PM
