Thread: boost gauge
Results 1 to 6 of 6
  1. #1 boost gauge
    GT Level Member titanfan12's Avatar
    Jan 2013
    west palm
    Well first off im installing a boost gauge, now what im haveing problems with is my boost gauge is reading negative for some reason.
    I really dont know much about gauges tbh, never had to deal with it before and any help would be great.
    Its going into the negative everytime and im useing the proper connectors etc.
    99 Silver Gtp here --------------------> http://www.grandprixforums.net/my-99...gtp-80323.html
    slp headers ,straight pipe, intriuge suspension, cai, ported tb, performance roller lifters, and bulit trans. 04+ seats in and le spoiler on
  2. #2 Re: boost gauge
    SWPA
    Have you taken it for a ride, or are you just looking at it while idling? The gauge will be in vacuum until you put load on the engine and create boost.
  3. #3 Re: boost gauge
    This
    04 Comp G.
  4. #4 Re: boost gauge
    Jan 2013
    west palm
    Your probably right guys, I might as well go try then because i was only doing it at idle. Going to go for a ride then, ill tell you guys what happens
  5. #5 Re: boost gauge
    Jan 2013
    west palm
    Two things. First what should it be idleing at or what should it be at when not pulling boost.
    Second can you guys post a picture of how you ran yours if you dont mind?.
  6. #6 Re: boost gauge
    HUDSON
    Vacuum is measured in Hg/in, boost is measured in PSI (pounds per square inch). I suggest you do some internets searches and some reading to educate yourself what they indicated and how they are measured. Most modern internal combustion engines at idle will have around 17 - 22Hg/in, and the stock L67 will have around 6.5-7 psi boost.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
