Thread: Horrible Startup Sounds......Slap?!?!
Results 1 to 10 of 10
  1. #1 Horrible Startup Sounds......Slap?!?!
    Ohio
    Ok my '05 GT is making some horrendous sounds when she first starts and it's like 20 degrees or less outside and has been sitting overnight. Doesn't sound like lifters. I thought maybe something trans related front pump etc. I have seen a few people talk about piston slap but I could not find a video of a 3.8 with a noise similar to mine. So here is a short video right after starting. The sound gets better after about 3-4 min and eventually goes away depending on how long it takes to warm up and how cold it is outside.
  2. #2 Re: Horrible Startup Sounds......Slap?!?!
    Florida
    Sounds like one cylinder is hitting something. Pull your plugs and look for damage.
    That's my old motor when I chipped a piston, and it was slapping against the head.
  3. #3 Re: Horrible Startup Sounds......Slap?!?!
    HUDSON
    Ouch, SHivers me spine like fingers on a chalkboard.
  4. #4 Re: Horrible Startup Sounds......Slap?!?!
    Ohio
    It goes away after it warms up a few minutes and she runs great. :-/ only 75,000 on her I would hate to have to bore and rebuild her
  5. #5 Re: Horrible Startup Sounds......Slap?!?!
    Florida
    I would still pull the plugs and see if they are damaged any.
  6. #6 Re: Horrible Startup Sounds......Slap?!?!
    Your video isn't working for me
  7. #7 Re: Horrible Startup Sounds......Slap?!?!
    St. Louis
    Pull your plus as suggsested. That doesn't sound good to me at all.
    Also, if this motor is trashed, there is no "bore and rebuild". These motor have a VERY picky bottom end and in the end it's cheaper/easier to find a low mile 3800 and swap it in whole.
  8. #8 Re: Horrible Startup Sounds......Slap?!?!
    SE Level Member transam24's Avatar
    Dec 2011
    NY
    Quote Originally Posted by FordMan77 View Post
    I don't understand why the 3800 gets such a bad reputation when it comes to rebuilding it. I am a firm believer that if you take the time and care to properly build ANY engine, and make sure everything is properly in specs then you should have no issue. I feel that the reason issues arise with people's rebuilds is that they just cheap out and slap it all back together with used parts. Personally I would rather spend a few extra bucks on piece of mind and Im in the process of rebuilding the engine for my Daytona. You just don't know what you are getting into with a junkyard motor.
  9. #9 Re: Horrible Startup Sounds......Slap?!?!
    HUDSON
    Quote Originally Posted by transam24 View Post
    The bad reputation comes from people not assembling the engine correctly. inexperienced people have no business being inside the crankcase of an internal combustion engine, much less a Series II/III 3800.
  10. #10 Re: Horrible Startup Sounds......Slap?!?!
    GT Level Member WolvesSoulZ's Avatar
    Québec
    I think people just say that it is cheaper to get a used bottom end, considering you can often get a 10-50k miles bottom end for like 200-400$. Way cheaper than a rebuild.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  1. Engine knock or piston slap?
    By Lunatic5oh in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-01-2012, 06:33 AM
  2. Connecting rod slap or knocking?
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2011, 10:14 AM
  3. Gonna ***** slap you and take your girl
    Last Post: 05-28-2011, 02:13 AM
  4. can you add slap shift?
    By Taz Magister in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2011, 04:16 PM
  5. 3800 s/c knocking noise or piston slap
    By GTPGuRu99 in forum Introductions/Noob Questions
    Last Post: 11-19-2010, 07:03 AM
