Thread: Engine knock or piston slap?
Results 1 to 4 of 4
  1. #1 Engine knock or piston slap?
    Sep 2012
    Indiana
    Hi all, relatively new to the forum. The girlfriend recently picked up a 98 Grand Prix GT (White, Two door, N/A 3.8). We bought this car off of my boss, who had the car for about a year. Anyways, the car has had the motor replaced about three times. I knew about this before the car was purchased. I believe that there is something simple going on to cause this; spark knock, fuel deprivation, lubrication deprivation, or just plain coincidence.
    From what I know the reason the last motor was replaced was due to a rough knock at idle. The current motor has what I would describe as a "rattle" more like piston slap. This seems to only occur under load, when the throttle is snapped open, or shut quickly, or if you float the throttle open and closed slightly around 2,500rpm. What I'm asking for is input based on this information as to what kind of common problems could possibly be taking out a N/A 3.8.
    Scanning with my Solus Pro shows me only a p0400 evap emissions code - no misfire codes, and no air metering codes. I see STFT at 100, and LTFT floats between 128-130 which I read on this forum to be about where it belongs. I don't believe the cat to be plugged up because the car still gets great fuel economy and does not lack power. Although the fuel trims are within range, the O2 B1S1 seems to read lean more often than rich - but seems to be reading properly. It does not have a dead miss, all the injectors are pulsing, pulse width seems to stay around 3.4-3.8ms at idle in park.
    The car is up at my shop, so I'm planning on trying to check fuel pressure, fuel delivery volume, and change the filter. I'm going to clean the MAF sensor although it was reading properly, as well as smoke test the intake for vacuum leaks.
    Any advice is greatly appreciated!
    Ohio
    If you could take a video of the noise then that would be great. Hopefully we can help you determine the noise
  3. #3 Re: Engine knock or piston slap?
    vid please.
    piston slap means you blew a rod bearing. thats the piston hitting the head. or the rod knocking around the crank.
    the n/a motors are known for blowing the upper intake gasket and dumping coolant into the motor, and of course it dies from that if un found in time.
    the good news is these n/a engine go for about $300 used all over the place.
  4. #4 Re: Engine knock or piston slap?
    The 3800 typically doesn't have the slap issues etc. Most likely if you can narrow it down to a certain RPM range, then it's likely something silly ... say an exhaust leak. Right amount of load, right angle of the flex in the downpipe and poof, you have a noise.
  1. 4th engine with rod knock
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 05-26-2013, 11:34 AM
  2. Engine Knock
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:49 PM
  3. 3800 s/c knocking noise or piston slap
    By GTPGuRu99 in forum Introductions/Noob Questions
    Last Post: 11-19-2010, 07:03 AM
  4. Need help, Engine Knock
    By valleyd01 in forum General Tech Discussion
    Last Post: 10-02-2009, 06:28 PM
  5. Do I have Engine knock?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:59 AM
