Thread: Moar voltage issues (I think)
Results 1 to 3 of 3
  1. #1 Moar voltage issues (I think)
    GT Level Member deadwoodspecial's Avatar
    Fuquay Varina, NC
    So I get in the car this morning to go to the grind, and as I'm heading down the freeway I notice my headlights are pulsating. Hmmm, it's not to my music so ? (I have an aftermarket head unit, and a set of subs with a 1000W amp that I know will cause it) I flip the DIC over to the voltage meter, and its reading right around 14.5... I also notice that my subs sound weak, if not non-existent... I stop at the gas station, check my subs to see if they're working, and they are coming in and out... Low power, right? Nooope... DIC still reads about 13.87 at an idle. That shouldn't be enough to cause them to cut in and out. There is a correlation with the pulsating of the lights, the amp, and whatever the Hell is going on. When I got to work, I'm sitting there fiddling with it, turning the subs off = Pulsing stops. Turn them on = Pulsing starts. Its almost like the amp is trying to fire, but doesnt have enough go juice to turn on and stay on. This leaves three areas for me to narrow it down to... Battery, Alternator, or Amp... Only problem I have is where do I start? Any ideas/ Suggestions?
    2008 Grand Prix Base
  2. #2 Re: Moar voltage issues (I think)
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    amp
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  3. #3 Re: Moar voltage issues (I think)
    is start with the grounds. that dumb post you 04+ guys have, and the amps ground.
  1. Now with less white and more function.
    By machinegunsquid in forum Members Rides
    Last Post: 02-26-2016, 01:43 AM
  2. Moar vids
    By MoarkatsINmuhtrailer in forum Track Sessions and Kills
    Last Post: 04-12-2013, 11:42 AM
  3. Das Auto...moar low to come
    By Twist in forum Members Rides
    Last Post: 09-30-2012, 01:27 PM
  4. MOAR Retrofit Customization
    By NegativeOne13 in forum How To Write-Ups/Tech Tips
    Last Post: 03-23-2012, 09:53 AM
  5. Need Moar FUUUUUUU in your life?
    Last Post: 07-13-2011, 11:12 PM
