Thread: whistle noise behind dash, why?
Results 1 to 12 of 12
  1. #1 Re: whistle noise behind dash, why?
    GXP Level Member
    Mar 2015
    Tomball
    Lol that whistle noise was just your cabin air filter more than likely as you have described it. When they get clogged up they will cause a whistle out of what sounds like the passenger side vents. when you get to about 80 it will also whistle. Change the cabin or clean it and problem solved.
  2. #2 Re: whistle noise behind dash, why?
    Nov 2011
    Indiana, PA
    uh no it wasn't... it was whistling sitting idle with all the fans off, it was a partially clogged tube
  1. noise coming from dash
    By bigtee in forum 5.3L V8 (LS4)
    Last Post: 07-13-2012, 07:58 AM
  2. Electrical buzzing noise in dash
    By GeeXPee in forum General Tech Discussion
    Last Post: 07-09-2012, 08:48 AM
  3. Weird howling noise under dash?
    By hjz8785 in forum General Tech Discussion
    Last Post: 07-25-2011, 10:29 PM
  4. High pitched noise coming from dash?
    By Gortox454 in forum General Tech Discussion
    Last Post: 08-14-2010, 08:48 AM
  5. swishing noise in dash
    By dwolf in forum General Tech Discussion
    Last Post: 03-10-2010, 05:45 PM
