http://shop.advanceautoparts.com/web...047%7CL3*16282
Anyone have any experience with this product? Negative or positive?
The link isn't working for me, but dorman makes good quality products.
You can get the ACDelco Pan for $35 on rockauto.
"Exact fit with 6 mm bolts"? hmm arent the bolts 10mm on our pans? wonder if it will fit...
97 is a M8 bolt, 98+ is a M6 bolt. Not to be confused with the size of the head...which on both is 10mm.
lol, we have time travelers on this forum? He's picking it up tomorrow, and getting it a month and a half ago, thats awesome!
If only good sir, if only... I'm trying to decide if I want to drop the pan and change the fluid and filter myself or have someone do it.... I've done it before on other cars, I just hate doing it, such a pain in the ass, and every time I do it, it ends up leaking, then again that was a Dodge car, so it had its' own set of problems...
Only things that cause it to leak are: bent pan(from letting it hang by too few bolts), badly designed aftermarket gasket, or not clean enough surfaces on pan and transmission, a well as a lack of cleaning the gasket if you're using the re-usable stock one.
Or not tightening bolts enough, that's another possibility.
And yeah mine's bone dry, I used the aftermarket gasket from the Wix kit.
^ yeah stock gasket is perfectly fine to reuse, just make sure it's as clean as a new one would be. No dirt or grime at all.
What happened? I remember seeing your posts, everything was good, then all of a sudden I saw, "got a TEP trans".
True, so many ways to mess things up.
