Thread: bolt up pattern on a transmission
Results 1 to 20 of 28
  1. #1 bolt up pattern on a transmission
    SE Level Member Feminist turnip's Avatar
    south dakota
    does a transmission from a 97 gtp bolt up to 04 gtp? im pretty sure it does since they kept the same block, but just want to have a definite answer before i spend the 300 bucks. thanks
  2. #2 Re: bolt up pattern on a transmission
    Charles City, IA
    It will bolt up, but will not work. You need an 03 plus trans.
    SMGPFC Two Nipple General
  3. #3 Re: bolt up pattern on a transmission
    yes................but you cant use it.
    97-02 are the same.
    03+ are differnt
    and you cant use a COMP-G tranny with the tap shift option.
  4. #4 Re: bolt up pattern on a transmission
    North Jersey
    so you could put say a '99 GTP trans on a '00 GT? if i'm following right???
  5. #5 Re: bolt up pattern on a transmission
    Quote Originally Posted by jerZcavy4120 View Post
    no
    GT trans is 4T65E 3.29 gear ratio
    GTP trans is 4T65E-HD 2.93 gear ratio
    you would have to custom tune the car to run it.
  6. #6 Re: bolt up pattern on a transmission
    North Jersey
    no
    thank you just always kinda wondered if it would work... had a friend asking thats why... thread hack is over
  7. #7 Re: bolt up pattern on a transmission
    south dakota
    aw dang was going to get a used tranny with a shift kit in it for cheap but now my dreams are crushed
  8. #8 Re: bolt up pattern on a transmission
    south dakota
    tell me again, what tranny could i use with the 04?
  9. #9 Re: bolt up pattern on a transmission
    Quote Originally Posted by Feminist turnip View Post
    try and find a tranny that came from the same model car as yours and is a 04+
  10. #10 Re: bolt up pattern on a transmission
    Charles City, IA
    04-08 4t65e Might be able to use an 03 not 100% on the 03 tho.
  11. #11 Re: bolt up pattern on a transmission
    North Jersey
    if you want a manual you could get the trans from i believe a G6... don't quote me on that, but i am certain that GP's can be made manual
  12. #12 Re: bolt up pattern on a transmission
    south dakota
    since you seen to be educated on transmissions, you think its worth installing a shift kit on my 04 since im out of a 2nd tranny?
  13. #13 Re: bolt up pattern on a transmission
    shift kits are always good. Helps firm things up and makes it better.
    get a Trans-go shift kit, if you buy one, from tripleedgeperformance
  14. #14 Re: bolt up pattern on a transmission
    south dakota
    alright o and for future reference is my tranny a 4T65E-HD or what kind of tranny is in a 04 gtp
  15. #15 Re: bolt up pattern on a transmission
    yea the HD
  16. #16 Re: bolt up pattern on a transmission
    south dakota
    k well i looked at triple edge performance and im not seeing the trans go shift kit. just seeing the overhaul kits and crap for volvo
  17. #17 Re: bolt up pattern on a transmission
    go to UPGRADES and scroll down, you will see it
  18. #18 Re: bolt up pattern on a transmission
    south dakota
    dang yr right again
  19. #19 Re: bolt up pattern on a transmission
    south dakota
    got one last ? here, my dads been a mechanic for 15-20 years and would hope he would help install, but hes to the point where if its not broke, dont fix it, so my question is, is it a difficult install?
  20. #20 Re: bolt up pattern on a transmission
  1. How to get 5x114.3 bolt pattern to fit
    By nascartech in forum Tires & Wheels
    Last Post: 01-19-2010, 02:45 PM
  2. whats my bolt pattern
    By tjsmithey in forum Tires & Wheels
    Last Post: 10-24-2009, 07:55 AM
  3. bolt pattern
    By jprovinsal in forum Tires & Wheels
    Last Post: 05-13-2009, 04:13 PM
  4. bolt pattern and offset question
    By kinglou10 in forum Tires & Wheels
    Last Post: 05-04-2009, 08:39 PM
  5. Wheel bolt pattern
    By 98GT3800 in forum Tires & Wheels
    Last Post: 10-12-2008, 03:27 PM
