Thread: car running unusually cool
Page 1 of 3 123 LastLast
Results 1 to 20 of 53
  1. #1 car running unusually cool
    Jun 2012
    Southern NJ
    Took a good while for it warm up this morning, was cruising gently and took maybe 5+ minutes to reach 140, and then it hovered around 160, even though I've got a 180* thermostat. I'm thinking it might be a leaky thermostat o-ring, partially stuck thermostat, etc.
    Any other ideas before I tear into it?
  2. #2 Re: car running unusually cool
    sounds like the t stat is stuck open, why not put a 195 back in like it should have.
  3. #3 Re: car running unusually cool
    Dec 2012
    Where 4T65E's were born
    Definitely sounds stuck open. I'd suggest a stock temp t-stat as well, or maybe a 192° if you like it running a bit cooler. I don't like running 180°'s in the winter myself. I've got to change mine soon.
    Sold.
  4. #4 Re: car running unusually cool
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    what year is it?
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  5. #5 Re: car running unusually cool
    May 2013
    97-00 let it be I don't mind running a bit cooler, scotty you commented on mine running no hotter than 172 why would it be a bad thing?
  6. #6 Re: car running unusually cool
    no point in running a colder thermostat unless you simply can't keep your car at operating temperatures because you live in texas. it does nothing for performance and just makes you lose gas mileage.
  7. #7 Re: car running unusually cool
    Quote Originally Posted by ntreftz View Post
    i dont recall ever telling any one to run a cooler t stat. ever lol if your all stock the engine is tuned to run at the temp it runs at for the best mpg and performance. most gm cars and trucks run at 210 or so. at least every one i ever owned. v8 and v6's.
    pretty much what bio said, if the fans dont turn on sooner, why bother, the car will still get up to 210 or more if it feels like it. 180 just opens sooner, then stays open and the temps still rise due to the fans not coming on sooner to cool it down.
  8. #8 Re: car running unusually cool
    SWPA
    This, this, and this.
  9. #9 Re: car running unusually cool
    Jun 2012
    Southern NJ
    This is kinda bull**** because I just bought this ****ing thermostat like 2 weeks ago. ****in' Stant.
  10. #10 Re: car running unusually cool
    bring it back. when you check it, it should be stuck open. when new in the box and cold, its closed, they will refund or replace it.
  11. #11 Re: car running unusually cool
    Jun 2012
    Southern NJ
    That's the plan. I just gotta pull it some time this weekend to bring back.
  12. #12 Re: car running unusually cool
    Dec 2012
    Buy the stant Superstat. It will say superstat on the box, much better quality than the "economy" level ones.
    Sold.
  13. #13 Re: car running unusually cool
    Jun 2012
    Southern NJ
    That's what I have!! Stant superstat, alt temp!
  14. #14 Re: car running unusually cool
    ive seen t stat fail asap in the past.
  15. #15 Re: car running unusually cool
    Jun 2012
    Southern NJ
    Might grab another 180*, honestly. It was perfect, it sat nice at 179 - 185.
    Gotta see about what I can do.
  16. #16 Re: car running unusually cool
    Dec 2012
    I've got that exact t-stat in my car now, no problems. It warms right up to 180 really pretty quick.
    Sold.
  17. #17 Re: car running unusually cool
    Jun 2012
    Southern NJ
    I have a warranty on the part, so I'm gonna swap it out on monday.
  18. #18 Re: car running unusually cool
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Most guys with smaller pulleys and higher boost run a lower temp tstat and program the fans to come on sooner. The idea is to keep the cylinders cooler and avoid knock. When my car was stock i ran a 195 but run a 180 now. I don't drive the car in winter and would probably switch it back if i did.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  19. #19 Re: car running unusually cool
    Jun 2012
    Southern NJ
    I'm going to be driving mine all year long, but it is built: S1X, 3.4", overkill etc etc etc.
  20. #20 Re: car running unusually cool
    Its like a 6-10 dollar part, don't get mad bro.
    And takes literally 2 minutes to change.
  1. l67 engine wont stay running..got the car running. tons of white smoke from exhast
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 05:14 PM
  2. 3.1L - Unusually High Fuel Economy Possible?
    By michaelb721 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-17-2010, 06:24 PM
  3. Running too cool -crap gauges?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2010, 02:26 PM
  4. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  5. 04 Grand Prix Check Engine/Running to cool
    By johnb62 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2010, 01:11 AM
