I'm stumped. Both low beams not working. I replaced one bulb 6 months ago, the other is original. Odd that they would both quit the same day. Swapped in a new bulb. Nothing. Checked the relays and switched low beam relay with fog lamp relay. Fog lamps still work. High beams work. Checked both fuses and they are good.
Not getting power? Possible but maybe a loose ground wire? Where would that be on a 2007 GT?
Thanks for any suggestions. Days are getting shorter and I have to get this fixed.
Joe
