Thread: Deleted Cat now worse milage?
Results 1 to 20 of 28
  1. #1 Deleted Cat now worse milage?
    Aug 2011
    'Merica
    Deleted the cat yesterday because I thought it was plugged. Replaced it with a straight piece of pipe. Now the car is getting worse milage then it did with teh cat. ? Our range went from 144mi on the DIC down to 90mi only driving maybe 30 miles. Any thoughts??
  2. #2 Re: Deleted Cat now worse milage?
    01+ cars use the rear o2 sensor to determine fueling is a way.
    So if it see's that the converter is not there, it will use more fuel. Also the cat test will keep running, thus using more fuel.
    Assume the check engine light come on already.
  3. #3 Re: Deleted Cat now worse milage?
    Aug 2011
    'Merica
    hasn't come on yet. weird...i know...what is the best way to go? have Greg delete it as if the cat is still there or buy a DP?
  4. #4 Re: Deleted Cat now worse milage?
    Get a downpipe with a cat, or just buy a cat and weld it in yourself.
    Spend anywhere from 90-150 bucks they come with somewhat good warrantys.
  5. #5 Re: Deleted Cat now worse milage?
    Aug 2011
    'Merica
    so having greg delete it in HPT or DHP won't thel my situation?
  6. #6 Re: Deleted Cat now worse milage?
    If he used HPT, it'd cost you 100 bucks just to licence the VIN/Car to change anything.
    DHP is free and I think still works on 04 and 05 cars, wont work on 06-08. Same with HPT, it's only good on 97-05 cars. (Except GXP, 05-08's work.)
  7. #7 Re: Deleted Cat now worse milage?
    Aug 2011
    'Merica
    if you had to choose between a DP and a new cat...what would you go for?
  8. #8 Re: Deleted Cat now worse milage?
    SWPA
    Don't base your findings on one day of driving. The DIC is ridiculously inaccurate, especially when it comes to the range. I can change the range just by how I park. Just recently on two different occasions I ran the car until the range hit "Low", which is at 40 miles. I stopped less than 5 miles after that I put over 16 gallons in the car, so if I had listened to the range indicator and tried to stretch it more, I would have run out of fuel.
  9. #9 Re: Deleted Cat now worse milage?
    GT Level Member Shiftingshaddow's Avatar
    KC
    I don't think there's any way to tell based on how much fuel you put in either. ive twice put in over 17 gallons and routinely it goes over 16 gallons. that's stopping at the first click. my gas gauge is broke so I have no way to really check anything. sure can't trust the dic. its gallon usage doesn't match the pumps.
    or maybe the gauge on the pump is jacked
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  10. #10 Re: Deleted Cat now worse milage?
    Jan 2012
    Philadelphia
    Quote Originally Posted by Shiftingshaddow View Post
    I use my DIC because I have no fuel guage, my range doesn't work either so I go by fuel used and mileage. I ran out of gas a few times, its not accurate but it works pretty good
    I havent had a working fuel gauge since Ive bought the car in 2010
  11. #11 Re: Deleted Cat now worse milage?
    KC
    [QUOTE=gtpeddie;1123019]I use my DIC because I have no fuel guage, my range doesn't work either so I go by fuel used and mileage. I ran out of gas a few times, its not accurate but it works pretty good
    I havent had a working fuel gauge since Ive bought the car in 2010[/QUOTE
    I did this at first with the car but it was routinely 3 or 4 gallons off. it works well with our minivan though. its pretty accurate. my other two gtps dics worked well. but they also had working fuel gauges.
  12. #12 Re: Deleted Cat now worse milage?
    Jul 2012
    Chicago
    My car's fuel range is more or less accurate when it's near empty (LOW MI) as long as its on a flat surface. Parking tilted to the left or or backward and I lose range, parking tilted to the right or forwards and I gain range.
    -Carl
  13. #13 Re: Deleted Cat now worse milage?
    gardner,mass
    Sparkplug non fouler trick in rear o2 for 5 bucks will fix your issue
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  14. #14 Re: Deleted Cat now worse milage?
    Aug 2011
    'Merica
    Quote Originally Posted by Ginseng View Post
    Will this seriously work?
  15. #15 Re: Deleted Cat now worse milage?
    Mine is fine with no cat. I had a hollowed cat on before that and the check engine light would only come on about one a month
  16. #16 Re: Deleted Cat now worse milage?
    Cool story.
    Your car isnt his car.
  17. #17 Re: Deleted Cat now worse milage?
    His car sucks le balls.
  18. #18 Re: Deleted Cat now worse milage?
    Florida
    FYI DHP does work for 96-05 cars.
  19. #19 Re: Deleted Cat now worse milage?
    Some could benefit by taking a minute and read the sticky about 01+ cars.
    Deleting the code isn't going to fix anything except a light bulb turning on.
  20. #20 Re: Deleted Cat now worse milage?
    Aug 2011
    'Merica
    will the non fouler trick work then?
  1. *deleted*
    By burgundybullet in forum Wanted To Buy - Parts
    Last Post: 08-13-2013, 11:54 AM
  2. So my EGR is deleted
    By KeithGTP03 in forum General Tech Discussion
    Last Post: 03-08-2011, 11:44 PM
  3. deleted
    By lukes prix in forum General Tech Discussion
    Last Post: 12-06-2009, 05:58 PM
