Thread: engine fire :(
Results 1 to 9 of 9
  1. #1 engine fire :(
    Oct 2012
    williamson ny
    so i had an engine fire, insurance said it is totaled...i would like to buy it back, but idk how hard it would be to repair it.....maybe new motor? suggestions? anyone?
  2. #2 Re: engine fire :(
    Need pictures to be able to tell you what you need to buy so it can be fixed.
    But figure you will need new valve covers and gaskets, new vacuum lines and a new wire harness. Maybe even a new upper intake manifold and some throttle body sensors.
  3. #3 Re: engine fire :(
    Feb 2013
    37.295091, -121.930053
    well you will also need a new wiring harness and a few other things. If your lucky it wont cost much.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: engine fire :(
    Oct 2012
    williamson ny
    ok, the car is still at the dealership, i will get pictures up when i can. but you would recommend buying it back?
  5. #5 Re: engine fire :(
    Cambridge, Ontario Canada
    Depending on damage, my 97 set itself on fire years ago in my garage. Whole front of car was totally destroyed. With the price of GP's no sense buying a half melted one imo. Pics will tell for sure though.
    2005 E55 - stock
  6. #6 Re: engine fire :(
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Yep these things are well known to have engine fires. My first 99 GTP went up in flames with an engine fire too. Luckily I had full coverage and State Farm hooked me up with a nice fat check for much more than I paid for the car. I ended up buying the current car which was basically mint and in ten times better condition than the 99. I agree with Elite6 that it all depends on how bad it burned and how much you like the rest of the car. How good of condition is the body and interior? Plus how much skill or recourses do you have to get it fixed? In the past three years I've learned how to do pretty much everything inside a 3800 engine bay but three years ago when the car burned I didn't have clue so I didn't want to mess with it. Basically if you love the car and its not toasted too bad and have a lot invested into other parts such as suspension, trans, paint etc. you may to keep it and repair. If its toasted pretty bad and the rest of the car is in disrepair I'd let the insurance company take it. Best of luck
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  7. #7 Re: engine fire :(
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    Parts seem to be fairly cheap for the GP's, so a buy back and motor swap may be pretty economical. Or you could possibly pick up a second donor parts car and then scrap off what you don't use.
    matt
    2004 Grand Prix GTP - work in progress
  8. #8 Re: engine fire :(
    Oct 2012
    williamson ny
    well i went through my insurance, and they dont allow buy backs on fire-damaged vehicles.........
    so i didnt bother to take pics, since i cant buy it anyways... sorta dumb i think....
  9. #9 Re: engine fire :(
    Pennsylvania, USA
    Did you figure out what caused the fire? I've heard of them happening for all sorts of reasons. Leaking valve cover gaskets, leaking injector/fuel rail o-rings, etc.
    It could definitely be worth it if the fire was put out quick enough and was isolated to just the engine bay. Did your hood have one of those fire smothering mats on the inside? I've never been certain of just how useful/useless they are in case of a fire.
  1. Might buy grand prix. help on engine fire!
    By Fox in forum General Grand Prix Discussion
    Last Post: 02-28-2012, 10:43 PM
  2. The Engine Fire Recall?
    By Importz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-11-2011, 07:23 PM
  3. engine stumble/miss fire etc...
    By Aj1984P in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-23-2010, 10:40 PM
  4. craigslist car $250 engine fire
    By 16MustangVet in forum General Tech Discussion
    Last Post: 04-14-2010, 03:54 PM
  5. Engine Fire
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2009, 12:26 PM
