Thread: window defroster
Results 1 to 3 of 3
  1. #1 window defroster
    SE Level Member Thinksun's Avatar
    Sep 2012
    GTP Ontario
    My window defroster does not work for any lines, I did have my windows tinted this summer. I could see a few lines broken but not all? There are two terminals on passenger side, one on drivers side and one on top (not sure if that is antenna?). Does anyone know what voltges I should see at terminals, or what impedance (ohms) I should have between terminals? Any testing advice appreciated, I did a search but results were not detailed as I hoped. Thanks
    1997 GTP .
  2. #2 Re: window defroster
    the lines that are small and tighter together are the radio antenna. the fat lines are the defrosters, so make sure the 2 wires are clipped on still or not broken.
    also check the fuse box if the def lights not coming on when you hit the button. if you have a light, my regal does.
  3. #3 Re: window defroster
    Sep 2012
    GTP Ontario
    The light on defrost button is on and fuses check out. There are different voltages at all tabs and this seems confusing. The tint guy had told me he cuts and lays everything out on exterior glass- his work is near perfect. I can see one line getting damaged but for all not to work seems odd. The tabs seem secure but maybe I better pull rear deck panel off and check wiring for shorts or breaks. ??
    1997 GTP .
  1. air only blows through defroster
    By fastcat in forum General Tech Discussion
    Last Post: 12-29-2012, 09:06 PM
  2. Rear Window Defroster - Fuse/Rely Location
    By 99XC600 in forum General Tech Discussion
    Last Post: 12-10-2012, 07:49 PM
  3. Help!! Defroster, Radio, Power Doorlock Problem
    By Sykkel in forum General Tech Discussion
    Last Post: 11-08-2012, 11:40 AM
  4. 04 rear window defroster
    By mikev69 in forum General Tech Discussion
    Last Post: 01-23-2010, 08:08 PM
  5. 2002 GTP Rear Defroster Problems
    By irex511 in forum General Tech Discussion
    Last Post: 01-21-2010, 05:54 PM
