Thread: Engine temperature
Results 1 to 14 of 14
  1. #1 Engine temperature
    SE Level Member MGRead's Avatar
    Jun 2012
    Coral Spring, Fl
    So I'm driving the car and its decides to stop showing temperature. Any help
  2. #2 Re: Engine temperature
    Jiggle the wires on the coolant temp sensor, or pound on the dash.....
  3. #3 Re: Engine temperature
    Jun 2012
    Coral Spring, Fl
    if I turn the car off it move to Max then back to nothing. Where is the sensor on my car
  4. #4 Re: Engine temperature
    under the t stat housing in the lim. aka under where the upper hose clamps on the engine.
  5. #5 Re: Engine temperature
    Jun 2012
    Coral Spring, Fl
    ok I see it. the car is way to hot to put my hand there. the car is not showing any code yet. I just had the oil changed on Friday. could they **** anything up
  6. #6 Re: Engine temperature
    Jun 2012
    Coral Spring, Fl
    also it on a 04 Grand Prix GT2 3.8 III
  7. #7 Engine temperature
    Not unless the moron that was changing the oil touched something he shouldn't have. Let the car cool off and then try it.
    04 Comp G.
  8. #8 Re: Engine temperature
    Ect sensor is probably bad
  9. #9 Engine temperature
    Jun 2012
    Coral Spring, Fl
    replace the ect still nothing. check the bolt and it keep dropping when temp go up
  10. #10 Re: Engine temperature
    Jun 2012
    Coral Spring, Fl
    scanner say ECT is working
  11. #11 Re: Engine temperature
    Jun 2012
    Coral Spring, Fl
    Any other help
  12. #12 Re: Engine temperature
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    I assume you checked coolant level when replacing ect?
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  13. #13 Re: Engine temperature
    Jun 2012
    Coral Spring, Fl
    check coolent level before posting.
  14. #14 Re: Engine temperature
    Jun 2012
    Coral Spring, Fl
    so car at the shop. they can't find out what happen. then the tech delete code! everything work.
  1. Replies: 2
    Last Post: 11-29-2012, 03:51 PM
  2. Engine temperature
    By 98gtp86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2012, 04:42 PM
  3. Very weird engine temperature behavior...
    By T0pwater in forum General Tech Discussion
    Last Post: 04-13-2011, 01:44 PM
  4. What is the normal engine temperature?
    By noname in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2010, 07:37 PM
  5. Engine Temperature Normal Range...
    By Chris in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2009, 08:17 AM
