Thread: engine thud low rpms low speeds
Results 1 to 16 of 16
  1. #1 engine thud low rpms low speeds
    Jun 2013
    Hollywood ,FL
    got a question for yall when im in 1 or 2 not in d and im at low rpms if I take my foot off the gas and then apply it I feel a thud like the motor or tranny is engaging this also happens at low rpms in 2 not sure if its the tranny or engine mount I already changed to poly uppers thanks for the help
  2. #2 Re: engine thud low rpms low speeds
    if your goosing the gas pedal, on and off real fast in a low gear your feeling the engine and trany trying to roll over under the hood. your mounts are probably in bad shape as well as the dog bone mounts. if you flip the bushings for the dog bones it makes the engine a bit tighter.
  3. #3 Re: engine thud low rpms low speeds
    Jun 2013
    Hollywood ,FL
    I already changed the dog bone mounts with polyurethane and yes that's what they feel like the only time I feel it is when the hear is in "1" or "2" at low rpms and not high im guessing it wouldn't hurt to change the mounts anyways since the car is used
  4. #4 Re: engine thud low rpms low speeds
    check the lowers out, they dont cost all that much really. easy to change as well.
  5. #5 Re: engine thud low rpms low speeds
    Jun 2013
    Hollywood ,FL
    know of any places that sell solid ones and not hydraulic aren't they like 40 a piece
  6. #6 Re: engine thud low rpms low speeds
    i just threw a set of duralast mounts in my regal, about 40 each. im all stock so i really dont need solid anything right now. i got about 8,000 miles on them. seem to be holding up ok.
  7. #7 Re: engine thud low rpms low speeds
    Dec 2012
    Where 4T65E's were born
    Napa has mounts that claim to be a solid rubber mount, I've heard they're like oem but I don't know for sure. You didn't post what car you have so I can't get part #'s. When I look up engine mounts for my car on advance's page, they show the hydraulic looking mount, but when they hand you the part it looks like the solid rubber mount.
    They say solid rubber mounts look like this:
    And hydraulic mounts look like this:
    Sold.
  8. #8 Re: engine thud low rpms low speeds
    Jun 2013
    Hollywood ,FL
    my bad buddy I have an 05 grand prix gtp non comp g
  9. #9 Re: engine thud low rpms low speeds
    There is a writeup on how to make your hydraulic mounts solid someplace. Iirc you drill some small holes in the rubber and drain out the fluid then refill the space with window urethane.
  10. #10 Re: engine thud low rpms low speeds
    Jun 2013
    Hollywood ,FL
    yea I could do that but would be simpler to find a solid one im sure someone has found some
  11. #11 Re: engine thud low rpms low speeds
    Dec 2012
    Quote Originally Posted by kurupt305 View Post
    Ok 04+ have completely different mounts it looks like. That's going by what comes up on advance's page anyway.
    Sold.
  12. #12 Re: engine thud low rpms low speeds
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    05 2005 Pontiac Grand Prix Engine Mount - Engine Mechanical - Anchor, DEA, Westar, Front, Front Right, Rear - PartsGeek
    the westar says if you want a solid you add s suffix,
    6th one down on that site 35$
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  13. #13 Re: engine thud low rpms low speeds
    Jun 2013
    Hollywood ,FL
    How do you add the s suffix to your order ?
  14. #14 Re: engine thud low rpms low speeds
    Jan 2013
    Edmonton, Alberta
    no idea,
    Westar EM2906S MOTOR MOUNTS Eng/trans Mount
    I went to westar's web site and they gave a part no. of em2906, and em2906s, (s for solid) so with those numbers I found this site for you.
    Please find out for sure if this part number is correct by cross referencing. I don't wont to be responsible for any wrong parts. The picture of the mount is not correct but youll see that when you go there (it says in the picture to). If you type in the part no. without the "s" it does show the correct pic for the hydraulic mount. So I do think this is the correct mount, and it seems to be cheaper at 28$
    this one below is the hydraulic filled one
    Westar EM2906 MOTOR MOUNTS Eng/trans Mount
  15. #15 Re: engine thud low rpms low speeds
    Jun 2013
    Hollywood ,FL
    hmm yea couldnt find the solid might ge tthe duralast from autozone
  16. #16 Re: engine thud low rpms low speeds
    Jan 2013
    Edmonton, Alberta
    that will be a great mount for you
    edit:
    I already found you one, part no. and everything, I just want you to double check
    westar em2906S
  1. Hard steering under low rpms and low speeds.
    By Bluemagic in forum General Tech Discussion
    Last Post: 06-25-2012, 12:06 PM
  2. Replies: 9
    Last Post: 04-16-2012, 03:10 PM
  3. Replies: 9
    Last Post: 07-06-2011, 12:19 PM
  4. Engine Misfiring @ High RPMs
    By skiderek in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2010, 05:57 PM
  5. Surging Through Low Speeds and No Check Engine Light
    By NapNinja317 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-15-2010, 11:06 AM
