Thread: no start after engine work!
Results 1 to 10 of 10
  1. #1 no start after engine work!
    Jul 2013
    wyoming, michigan
    Hi so to start I just completed a xp cam install ported head gen v swap with northstar I have a canned tune from zzp. So the problem is I got everuthing back together and it won't crank the security light on the dash is flashing. And I have no fuel pressure. I tried the security reset procedure with no luck. Can anybody offer a suggestion as to any sensors thay would cause no crank or fuel pressure or what else I should do to reset the security system ... srry for the lack of punctuation I'm tired and don't care lol
  2. #2 Re: no start after engine work!
    Have you checked the basics...like the battery, starter, terminals and ground?
    04 Comp G.
  3. #3 Re: no start after engine work!
    Fuel pressure can still be had with the security light flashing, so you likely have no power to the fuel pump.
    That light can disable the injectors though.
    For no crank, look at your starter wires.
    Do you have the stock PCM?? Just to see if it will fire?
    Having a canned tune with those mods isnt a good idea either.
  4. #4 Re: no start after engine work!
    Jul 2013
    wyoming, michigan
    The canned tune is just to get it on the road til a dyno tune can be done its also on stuck pullet right now... the battery is good for sure and the wires connected to it. And I don't have the stock pcm thos was brought to zzp to ne tuned
  5. #5 Re: no start after engine work!
    put the stock pcm back in, if it cranks and runs its the pcm needing a case learn maybe.
    if you still get nothing, you left a wire off or something somewhere.
  6. #6 Re: no start after engine work!
    Jul 2013
    wyoming, michigan
    Ha just found a ground I missed on the tranny. Maybe that will do it. Ill leave u in suspence a minute and let ya know how it goes
  7. #7 Re: no start after engine work!
    the battery ground is the problem for the no crank for sure.
  8. #8 Re: no start after engine work!
    Jul 2013
    wyoming, michigan
    Yup starts fine now but I have a hell of a tick... and the n* throttle does not seem to rest back on idle after giving it some gas any ideas?
  9. #9 Re: no start after engine work!
    ive read that a few guys have trouble with the cable being to tight some times, the cable could be not clipped in right. should be a bit of slack.
    the tick could be a lifter that just has not pumped up yet if it hasn't been run to long yet.
  10. #10 Re: no start after engine work!
    May 2012
    Where winter never ends
    After my cam install my lifters ticked for a minute or two after until they pumped up with oil. Now its all injector clicking and ebay headers leaking noises lol! :P
  1. 04 GP remote start wont work.
    By Fcukit33 in forum General Tech Discussion
    Last Post: 09-13-2012, 01:52 PM
  2. Remote start - Used to work great now after some messing around it does not work.
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 06-12-2012, 11:24 AM
  3. Remote start wont work
    By BennysGP in forum General Tech Discussion
    Last Post: 02-03-2011, 01:42 PM
  4. Car wont start on initial try, will work 2nd try always
    By Jsedor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2010, 10:44 AM
  5. Remote Start won't work
    By Jesse in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:14 PM
