Thread: Help with motor swap
Results 1 to 13 of 13
  1. #1 Help with motor swap
    Aug 2013
    Springfield mo
    Ok so I have a 2001 gtp that I am getting ready to put a different motor possibly transmission out of a 97 I know the motors will interchange but I need to know the difference between the transmissions also would I need to swap computers or anything else
  2. #2 Re: Help with motor swap
    the 97 trans wont work, the engine should be as easy as old one out, new one in, plug and play deal. you'll want to use your TB though. your sensors are different maf and such.
  3. #3 Re: Help with motor swap
    Sorry Scott..
    Trans will work as long as it's GTP to GTP. The only differences on the engine are the alternator, alternator bracket and the evap stuff. So if you swap your 01 stuff onto the 97 engine..you will be all set. Drop it in and use 2001 computer.
  4. #4 Re: Help with motor swap
    i always for get the vac line tranny is a n/a deal.
  5. #5 Re: Help with motor swap
    Aug 2013
    Springfield mo
    What's the difference on the tb and what's the difference between the two transmission
  6. #6 Re: Help with motor swap
    Aug 2013
    Springfield mo
    They are both gtps I have both cars one is just rusted out and I don't want to do a transmission swap if it won't work I heard the 97s transmissions are better but don't know for sure
  7. #7 Re: Help with motor swap
    Jersey
    97 gtp trans is the same. 97 gt trans is garbage, its a weak vacuume controlled unit
  8. #8 Re: Help with motor swap
    only real difference is what bill said, a hand full of sensors need to be taken from your old engine and put on the 97 engine, 97 used different sensors that wont plug into your harness.
    if the 97 has not had the lim gaskets done yet, do them before you put the engine in the car. but put your lower intake, blower, TB, and injectors, fuel rail and alt bracket and alt from the 01 on the 97 engine.
  9. #9 Re: Help with motor swap
    Aug 2013
    Springfield mo
    Ya I have already ordered gaskets for the top end of the motor planned on using the 01 fuel rail alternator etc but planned on using 97 blower it's brand new why the injectors?
  10. #10 Re: Help with motor swap
    why not the injectors? lol they got to be newer then the 97 injectors.
    if you unbolt the fuel rail, and lift it off with the injectors still in it, then lay it to the side, then you just put them back on the new motor.
  11. #11 Re: Help with motor swap
    Aug 2013
    Springfield mo
    I didn't even think about that lmao but not really my 01 has twice the amount of miles
  12. #12 Re: Help with motor swap
    The 99+ TB has a different maf sensor. So swap the TB.
    Here's your list of things to swap.
    TB
    EVAP and vacuum lines (plug the ports from the tree next to the TB on the 97 charger)
    Alternator
    Alternator bracket
    Check the coolant sensor in the LIM.. might be different, might not.
    That should be it.
  13. #13 Re: Help with motor swap
    Aug 2013
    Springfield mo
    Thank you for your help will let you know how everything goes
  1. SC motor swap
    By kking89 in forum General Tech Discussion
    Last Post: 09-20-2011, 05:23 AM
  2. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  3. 3rd motor swap in car
    By learnAsUGo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2011, 05:42 PM
  4. Motor Swap
    By Rolling89GPSE in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-26-2010, 05:09 PM
  5. Motor swap
    By tracker1925 in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-26-2010, 03:44 PM
