Thread: fog light issue
Results 1 to 8 of 8
  1. #1 fog light issue
    Aug 2013
    sevierville
    Got a question?!?!? i have a 2004 grand prix My fog lights just out of no where stopped working. The fog light indicator still come on in the internment panel but no fog lights,does anyone know why there not working now?
  2. #2 Re: fog light issue
    Check the bulbs
  3. #3 Re: fog light issue
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    ^ I was going to say that.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  4. #4 Re: fog light issue
    Jan 2013
    michigan
    i'd check the bulbs
  5. #5 Re: fog light issue
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Bulbs or actual fuse in underhood fusebox. I've seen burnt up plugs as well.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  6. #6 Re: fog light issue
    Aug 2013
    sevierville
    Iv checked the bulbs iv check all fuses,
  7. #7 Re: fog light issue
    Pennsylvania, USA
    If you have a multimeter, you can turn on the fogs and put the leads in one of the plugs to see if there's voltage getting to the bulbs. That will rule out a wiring issue.
    Also, I don't remember if the second fuse box in the car (not under the hood) has anything to do with fogs, but it may be worth checking those fuses as well.
  8. #8 Re: fog light issue
    Oct 2011
    MI
    There is also a fog light relay I believe
  1. temp light issue
    By disblile in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2016, 12:55 PM
  2. DIC issue with trac light
    By josbourn1 in forum General W body
    Last Post: 11-10-2012, 12:53 AM
  3. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  4. Tail light issue.
    By MeetLacey in forum General Tech Discussion
    Last Post: 02-08-2012, 11:26 AM
  5. Right Running Light Issue
    By mlasnoski in forum General Tech Discussion
    Last Post: 09-30-2010, 10:21 PM
