Thread: Gas Gauge not working, I've tried everything!!!
Results 1 to 2 of 2
  1. #1 Gas Gauge not working, I've tried everything!!!
    Mar 2013
    United States
    Hi again guys! I've had this issue with my car since I got it. Gas gauge won't work. It's stuck at a hair over half way.
    Things we've already tried:
    • replaced entire fuel pump assembly - nothing
    • checked for bad wires - nothing
    • connected purple fuel sensor wire directly to sending unit - when disconnected it goes to empty, when again connected goes back to the hair over half a tank.
    Now the oddest thing. The cluster says it was a 1998 manufacture, and the car was manufactured in Sept. of 1996.
    Car is a 1997 Grand Prix SE 3.8L non-supercharged.
    Please help I'm at wits end! THANKS IN ADVANCE
    ALSO! If cluster is swapped out, do you thing it'll work or not? I read something about the 1997 gas gauge working differently ...and I'm pretty sure that the cluster was swapped without telling me before I bought it. Otherwise, it would be the same manufacture year right?
  2. #2 Re: Gas Gauge not working, I've tried everything!!!
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    97's are known for this!
    You need to pull the pump and install a new sending unit/float arm.
    It needs one specificly for a 97, the one in the fuel pump assembly you got may not be correct if not.
  1. 01 GTP gas gauge not working
    By sheltonb13 in forum General Tech Discussion
    Last Post: 02-16-2013, 11:15 AM
  2. Gas Gauge not working!
    By gtpeddie in forum General Tech Discussion
    Last Post: 03-04-2012, 07:08 PM
  3. Gas Gauge not working
    By tooslow in forum General Tech Discussion
    Last Post: 08-07-2011, 02:37 PM
  4. gas gauge not working!!!!!!!
    By chancinit666 in forum General Tech Discussion
    Last Post: 06-04-2010, 03:54 PM
  5. Help!!! Gas Gas gauge not working
    By PontiacGTPSE in forum General Tech Discussion
    Last Post: 07-09-2009, 12:30 PM
