Thread: Transmission or Throttle Positioning Sensor?? Help!
Results 1 to 9 of 9
  1. #1 Transmission or Throttle Positioning Sensor?? Help!
    GT Level Member kyliek23's Avatar
    Feb 2013
    ok, i have been having issues with my GP again. When im at a complete stop or rolling to a stop at a stop and go light or a stop sign, i push on the gas and my gar jumps forward like it wasnt fully in gear. i thought it was because i was on either a crack or a part of the road paint to where it was slipping on the pavement that resulted in that. Or my transmission is taking a crap on me. My boyfriend told me it might be my TPS (throttle positioning sensor), that its not reading right. i need some opinions and advice.
    2005 Pontiac Grand Prix Base
  2. #2 Re: Transmission or Throttle Positioning Sensor?? Help!
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    if it's the tps it will throw a code..
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  3. #3 Re: Transmission or Throttle Positioning Sensor?? Help!
    Feb 2013
    hmm.. maybe ill have to check to see if it sends a code. i didnt check that yet. so ill see and let everyone know. thanks
  4. #4 Re: Transmission or Throttle Positioning Sensor?? Help!
    Even if it didn't set a code.. you can check it.
  5. #5 Re: Transmission or Throttle Positioning Sensor?? Help!
    Feb 2013
    How can I do that? would you think that its bad it would start doing this to my car?
  6. #6 Re: Transmission or Throttle Positioning Sensor?? Help!
    Bastard Reptile's Avatar
    Kansas City, MO
    Even if the TPS was bad, it should go forward like it always does, and it would likely set a code. Sounds like something inside the transmission isn't applying correctly. I think there's something like the apply piston seal wears, and it slips in first and acts like it's not in gear, then bangs forward like you just put it in D.
  7. #7 Re: Transmission or Throttle Positioning Sensor?? Help!
    Feb 2013
    Is that going to cost a lot to fix? And how do you even find out what's wrong?
  8. #8 Re: Transmission or Throttle Positioning Sensor?? Help!
    You test..
    Start out by taking it to a trans shop for a basic diagnostic.. They can hook up stuff that will tell them if engine load vs rpm in vs out etc are good. That will get you started for learning what is wrong.
    If the piston is bad.. most shops would automatically rebuild.
  9. #9 Re: Transmission or Throttle Positioning Sensor?? Help!
    Feb 2013
    Ok. I'll take a look and see what I can find. See what shop to take it to and go from there. Hopefully there's nothing wrong and its just being mental. Lol.
  1. Brake Pedal Positioning Sensor
    By DrDino in forum Introductions/Noob Questions
    Last Post: 01-21-2011, 12:38 AM
  2. throttle position sensor
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2010, 11:16 AM
  3. THrottle position sensor
    By xsvtank in forum General Tech Discussion
    Last Post: 11-27-2010, 07:17 PM
  4. low volts on throttle positioning sensor????
    By DONDON3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2008, 03:28 PM
