Thread: 99 Grand Prix won't start
Results 1 to 20 of 22
  1. #1 99 Grand Prix won't start
    SE Level Member Yamahakid88's Avatar
    Jun 2013
    Illinois
    The car will sometimes start after sitting for awhile. I left it on a float gather over night and went to start it for work and it started right up. However I tried to leave work and of course, didn't start. It has a newer battery only 2-4 months old, when turning te key I can hear the fuel pump, but I do not hear the starter even attempting to move. All dash and entry lights come on but nothing else. I testing the battery output and it comes out as 12.4 volts which should e plenty enough to start it. Please help guys, I really need this car for work etc. thank you. Any advice is appreciated
  2. #2 Re: 99 Grand Prix won't start
    Quote Originally Posted by Yamahakid88 View Post
    Translation please.
    While you hold the key..have someone hit the starter wtih a hammer.. If it fires up.. you need a starter.
    As for testing the volts to start the car, that isn't a very good test. You need to test amps. If you want to do that..ask a parts store to test the battery for you.
  3. #3 Re: 99 Grand Prix won't start
    Jun 2013
    Illinois
    Sorry, auto correct. I left it on a float charger! Well im pretty certain it is not the battery. Could it be a faulty ground? I've heard that security systems on this car could prevent it from starting.
  4. #4 Re: 99 Grand Prix won't start
    Jun 2013
    Illinois
    No one? :/
  5. #5 Re: 99 Grand Prix won't start
    did you toss the starter a beating yet like bill suggested? sounds like a bad starter.
  6. #6 Re: 99 Grand Prix won't start
    GT Level Member Shiftingshaddow's Avatar
    KC
    sounds like the starter to me
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  7. #7 Re: 99 Grand Prix won't start
    Jun 2013
    Illinois
    I just replaced the starter and it does the exact same thing, i was able to short out the starter, and what do ya know. it started. Confused..
  8. #8 Re: 99 Grand Prix won't start
    could be a bad ignition switch ( what the key turns). or harness. pretty sure its all one harness.
    anything else acting up, heater fan? dash lights? directional's or head lights or horn?
    at least you can jump the starter and drive it till you get to the bottom of it. just carry a long screw driver.
  9. #9 Re: 99 Grand Prix won't start
    Jun 2013
    Illinois
    nothing else is acting up, id rather not short it out every time i want to start it, can be a pain
  10. #10 Re: 99 Grand Prix won't start
    I'm assuming you checked the relay like matt suggested?
  11. #11 Re: 99 Grand Prix won't start
    Jun 2013
    Illinois
    i did, swapped them out, and nothing
  12. #12 Re: 99 Grand Prix won't start
    Then I would lean towards ignition switch.
  13. #13 Re: 99 Grand Prix won't start
    Jun 2013
    Illinois
    ok, if i replaced the ignition switch, would i need new keys?
  14. #14 Re: 99 Grand Prix won't start
    no new keys are needed, your changing the part the key turns, its a black box, and its harness down the column.
    heres a how too. Sparky's Answers: 2002 Pontiac Grand Prix, Changing The Ignition Switch
  15. #15 Re: 99 Grand Prix won't start
    Jun 2013
    Illinois
    Great article! Should i first try the switch? Or replace the harness altogether?
  16. #16 Re: 99 Grand Prix won't start
    not even kidding here, slap the side of your column by the key, where the box is in those pics, see if it starts. if it cranks, you know your on to something.
    the switch is part of the harness. he dont show it out of the car, just in the car still, its a fat set of wires running down the column to under the dash. it leads the the fat plug he shows at the end under the dash.
    if you have a junk yard by you, go get a used one, this way you break stuff in the jy car learning how to get it apart, and the part cost much less used.
  17. #17 Re: 99 Grand Prix won't start
    Jun 2013
    Illinois
    I will do that! Thanks i will keep you posted
  18. #18 Re: 99 Grand Prix won't start
    Jun 2013
    Illinois
    Could it actually be the battery guys? I ran it dead once when washing the car, charged it up. Then that night i tried to start it and it didnt work. So i hooked it to a float charger overnight and it started up?
  19. #19 Re: 99 Grand Prix won't start
    test the battery with a load tester at a parts store. also check the date on the battery, if its at or past its months of life it could be dying a slow death on ya.
    also have the alternator tested, if its not charging at 13.9 or higher that could be the problem.
  20. #20 Re: 99 Grand Prix won't start
    Jun 2013
    Illinois
    thats the problem i cant move it anywhere without shorting the starter :/ this car is making me mad...
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. 94 Grand Prix will not start
    By AMXTRA in forum General Tech Discussion
    Last Post: 10-07-2012, 04:20 PM
  3. 99 Grand Prix GTP no start
    By atvrider85 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2010, 11:26 AM
  4. 97 Grand prix won't start... Need help... BAD...
    By 98gtxking in forum General Tech Discussion
    Last Post: 10-08-2009, 10:50 PM
  5. 97 Grand prix won't start... Need help... BAD...
    Last Post: 09-24-2009, 02:54 PM
