Before you buy anything you need to take off the intake tube and verify your tb blade moves smoothly also push it back the opposite direction and make sure it do sent stick sometimes that can happen when the blade snaps back after give it some gas and will stick causing the reduced power mode as well...solution lightly sand the area in the tb bore with some 600 then 1000 till you get full movement
