Thread: adjust carb.
Results 1 to 10 of 10
  1. #1 adjust carb.
    Sep 2013
    ky.
    My '70 gp smells of gas and runs rough. If this is the carb. how do you adjust it.
  2. #2 Re: adjust carb.
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    what carb is on it?
    what year, what engine?
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  3. #3 Re: adjust carb.
    Sep 2013
    ky.
    its a four barrell thats all i know
    1970 grand prix 400 motor
  4. #4 Re: adjust carb.
    I'm sure cleaning it and rebuilding the carb with new jets would make a world of difference.
  5. #5 Re: adjust carb.
    St. Louis
    If it's the stock carb, I'd be willing to bet its a Rochester Quadrajunk, I mean Quadrajet. Would def. do a rebuild on it as these carbs are notorious for running rich. Then from there you can adjust as needed.
  6. #6 Re: adjust carb.
    Jan 2013
    Edmonton, Alberta
    does it look like that
  7. #7 Re: adjust carb.
    Sep 2013
    ky.
    yep thats it.
  8. #8 Re: adjust carb.
    thats a quadrajet carb. aka quadrabog lol
    you can get a new one, or rebuild the one you have.
    theres 2 screws in the front of the carb by the lower plate, start the car, turn the screws in till the car starts to stall out, then turn them back out till it smooths out.
    its best to first turn the screws in all the way, counting the turns in, that way you know where you started.
    1 and a 1/2 turns out is a good place most of the time to start out.
  9. #9 Re: adjust carb.
    Jan 2013
    Edmonton, Alberta
    this guy has a bunch of utube videos
    http://www.youtube.com/watch?v=XRCUibTkm3o
  10. #10 Re: adjust carb.
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    whats a carb lolol
  1. autolite 2100 carb
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 04-04-2010, 05:21 PM
  2. carb cleaner + blower rotors= FAIL
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2010, 09:59 AM
  3. SLP intake for l67 come with a carb sticker
    By 01gtprocket in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-19-2009, 10:43 PM
