Thread: help ac/heater and head light problem
Results 1 to 17 of 17
  1. #1 help ac/heater and head light problem
    Aug 2012
    Tukwila, Washington, United States
    so i had this problem that the heater some times stops and i need to turn it off and on the fifth.
    yesterday i had this weird thing, no blower, and the switch turn off the head lights (watch video)
    i googled for solutions and found some more ppl with this problem see link Issues with Headlights and Heater/AC Fan Motor - Grand Prix Net
    i just cant figure it out how to fix it.
    please help me find out. its still cold here.
    Grand Prix gt 1999 v6 3.8L coupe.
  2. #2 Re: help ac/heater and head light problem
    Aug 2012
    Bump:
    Anybody know about this ignition switch problem?
    Any way to fix it easy?
  3. #3 Re: help ac/heater and head light problem
    Feb 2013
    37.295091, -121.930053
    i would start with plugs in the back. you may have a wire not plugged in right. to me it looks like its pulling more power than it should. also to when you touched the headlight switch all your lights blinked.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: help ac/heater and head light problem
    its not all that bad to change. heres a good how too. its for a 02, but it cant be all that different. Sparky's Answers: 2002 Pontiac Grand Prix, Changing The Ignition Switch
  5. #5 Re: help ac/heater and head light problem
    Aug 2012
    Id pay you to do it for me.
    That looks like a headache.
  6. #6 Re: help ac/heater and head light problem
    once all the plastic is off its a harness that bolts under the dash, its coupled with the multi switch, aka blinker switch.
    you stick a awl or pick in the tumbler re release hole to get the lock out, and swap the harness.
    all the wires your playing with have plugs too, its not like your splicing it together.
  7. #7 Re: help ac/heater and head light problem
    Aug 2012
    To be honest I'm not sure what part exactly need to be replaced.
    I just need my ac to work.
    If theres an easy fix for it besides replacing the whole ignition
    It would be better.
    Something like plugging something back.
  8. #8 Re: help ac/heater and head light problem
    this is what you need to change, the round part on the box there is what the key turns to start the car.
    see the box under the key hole in this pic, from sparky how to.
  9. #9 Re: help ac/heater and head light problem
    Banned
    Sioux Falls, SD
    I have a switch out of a car with 32K
  10. #10 Re: help ac/heater and head light problem
    they dont seem to be cheap either. used would be a good route to go.
  11. #11 Re: help ac/heater and head light problem
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    This junker gp i have sorta has the same problem, only difference is its the dash lights that die its a pain in the butt, & How the heck did you get a double din radio in there
  12. #12 Re: help ac/heater and head light problem
    Feb 2013
    ^^ i second that i want to Double Din my radio too.
  13. #13 Re: help ac/heater and head light problem
    Aug 2012
    i guess i need to see a junk yard soon.
    about the double din.all pioneer double din (6.5 inch screen) will fit there and i used plastic sheets for the sides and some plumbing thing to hold it inside.
  14. #14 Re: help ac/heater and head light problem
    Aug 2012
    So I tried to see which part is bad and touch parts of the wires.
    When I hit this box with the screw driver my ac is back to work .
    I hope it last.
  15. #15 Re: help ac/heater and head light problem
    probably a temp fix. but that narrows it down for sure.
  16. #16 Re: help ac/heater and head light problem
    Aug 2012
    I hope it will last forever. Or at least till I save up for a new car.
    Thank you for your help.
    Wow I'm so happy I almost forgot I got a ticket today.
  17. #17 Re: help ac/heater and head light problem
    Feb 2013
    LAMO I hope she stops nickel and diming you. So that you can enjoy her.
  1. Replies: 8
    Last Post: 08-20-2015, 07:52 AM
  2. heater/ ac problem 3.8
    By brady22 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-20-2012, 10:27 PM
  3. Head light and fog light setup
    By Dzebold in forum Visual/Body Modifications
    Last Post: 04-12-2012, 04:39 PM
  4. An all out A/C / Heater Problem
    By HDGlassArt in forum General Tech Discussion
    Last Post: 11-01-2011, 01:53 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
